07-28-2005, 03:23 PM
John,
I see on your site you do have the SC carb adapter I mentioned earlier. Like I said I’d try using it’s threaded bolt holes in the front for an attaching point for the throttle bracket and go from there.
On the tensioner pulley…I tried to warn you about the fit!…lol. I have yet to hear from anyone with this B&M blower who installed the kit’s tensioner pulley assembly in an L body that got it to work properly. In your pics the mods made look really good. I hope it works out for you.
I know other guys that have made up their own tensioners for the B&M kit and some of them have used a spring loaded pulley that pulls the belt inward from the outside of the belt, just like a serpentine belt. That style seems to work good.
Other than the clearance issue, biggest thing on the tensioner pulley is to make sure there is enough spring tension on the belt to keep it from slipping too much or you won’t make hardly any boost.
On mine, I just skipped the whole tensioner ordeal and used a smaller belt, tightening it with the PS pump…works good so far.
Good luck and let us know how you make out.
