Go Back   TurboDodge.Com - Turbo Dodge forum for Turbo Mopars, Shelbys, Daytona, SRT-4, PT Cruiser, Omni and more! > Turbo specific > RWD Turbo-Dodge
Old 09-14-2009, 09:40 PM   #76
Re: Turbo Dakota
My Ride: 87 Shelby Z
Do you happen to have a tach or a scanner to check the RPM at highway speed. Mines extremely low for a 4 cly. Has the power dropped or has it always been like this since you've owned it. The 4cyl dodges tend to have a miss at idle.
bfarroo is offline
Old 09-14-2009, 10:46 PM   #77
Re: Turbo Dakota
My Ride: dakota
It's been like that since I got it. I don't have a tach.
ramracer is offline
Old 09-16-2009, 02:37 PM   #78
Re: Turbo Dakota
My Ride: 1989 lebaron gtc
Engine: 2.2turbo t2 shelby
found it guys read for about an hour got to
drill the crank
Hemi417 is offline
Old 10-08-2009, 06:15 PM   #79
Re: Turbo Dakota
My Ride: 86 Shelby Charger
Originally Posted by Hemi417 View Post
hey guys i ran into a problem on mine ,somebody at one time told me to use a Dakota crank, i didn't have one so i used the fwd crank , manual , the imput shaft seems to long. it goes into the pilot bearing and stops against the crank so that the bell housing is 1/4 inch from bolting up ,my solution is to take a grinder to the imput shaft and shorten it but before i go hacking i want to c if there is actually a difference or if i need to look somewhere else ,(its hard to c in there lol) i didnt know if anyone knew of a lenght difference between the ax-15 and the front wheel drive stuff or if the cranks where drilled different this is an 87 t2 crank , I know it is vague but any help would be appr.
what year was the crank out of for the fwd? they didnt start drilling out the crank for the pilot bearing till 86 for the rwd in the dakotas. found that out while doing the research for mine. its in the 2.2/2.5 fwd performance book
glhswanted is offline
Old 10-08-2009, 08:55 PM   #80
Re: Turbo Dakota
My Ride: 1992 Daytona R/T
Engine: 2.2 TIII
I need to drill a crank for RWD. It's a common-block. Can anyone tell me exactly what drill size and depth required?
gkcooper is offline
Old 10-17-2009, 03:06 PM   #81
Found this on Ebay
Engine: 2.2 TIII
Dodge : Dakota:eBay Motors (item 250514911476 end time Oct-22-09 15:02:00 PDT)
gkcooper is offline
Old 10-19-2009, 03:43 PM   #82
Re: Turbo Dakota
My Ride: 87 GLHS
Engine: 2.2 turbo
Greg,,what is the status of your truck?
derek502 is offline
Old 10-19-2009, 05:33 PM   #83
Re: Turbo Dakota
Engine: 2.2 TIII
Derek, still DD on the 2.5 TBI. I got the Hybrid 2.5 mockup still on my bench where it has been for the past year. I have a Holset HY35W turbo for it. I did cut a custom underdrive pulley for it that is for a K (six-groove) serpentine belt.
gkcooper is offline
Old 10-19-2009, 05:36 PM   #84
Re: Turbo Dakota
Engine: 2.2 TIII
You can install an instrument cluster that includes a Tach but you will have to run the tach wire from the SBEC to the cluster. The 4 cylinder Dakota harness did not include the tach wire. It will work just fine after that.
gkcooper is offline
Old 10-19-2009, 09:18 PM   #85
Re: Turbo Dakota
You don't have to do anything to take into account for the # of cylinders? I may have to look for a cluster that has one. Having a tach would be nice.
bfarroo is offline
Old 10-20-2009, 08:40 AM   #86
Re: Turbo Dakota
Engine: 2.2 TIII
No, the signal comes from the SBEC or SMEC. The instrument cluster is just a display device.
gkcooper is offline
Page generated in 0.18307 seconds with 9 queries
