Go Back   TurboDodge.Com - Turbo Dodge forum for Turbo Mopars, Shelbys, Daytona, SRT-4, PT Cruiser, Omni and more! > Turbo specific > RWD Turbo-Dodge
Old 10-15-2006, 04:22 PM   #1
towing capacity 2.5l 5sp man Dakota?
Does anyone know what the rated towing capacity is for a 2.5l NA Dakota?
SOHC 2.2/2.5 family motor (not the later Jeep derived 2.5l 4 cylinder version)
DaveR is offline
Old 10-15-2006, 06:05 PM   #2
i dont know of any factory specs but i towed an 86 hurst olds with mine and it did ok. wouldnt want to go long hauling but a simple across town move you would be ok.
hope this helps and good luck
flight704 is offline
Old 10-16-2006, 07:43 AM   #3
5,000 + lbs if you do it right.
22dodge is offline
Old 10-16-2006, 09:30 AM   #4
My Ride: 91 Spirit R/T
Engine: TIII, 2.2
I think the factory # is 2,000lbs. That dose not mean you can't tow more than that, but that is all your drivetrain / chassie was designed for. I had a ranger with the 2.9 V6 I towed cars on flat bed trailers with. It was only rated for 3500lbs. I was just really careful.
Boost_virgin is offline
Old 11-05-2006, 09:47 AM   #5
those 5spd trannies behind the 2.5 in the dakota are the weak link. the 2.5 itslef is a decent towing engine if you got it geared right, but its not a good choice for a large load unless you turbo it and do everything to ensure long-haul durability
capev86 is offline
Old 11-06-2006, 09:33 PM   #6
My Ride: 88 Shadow
Feedback: (6)
What tranny is the one in the dakota similar too in terms of handling power? 525, 520, 555?
moparzrule is offline
Old 11-06-2006, 10:03 PM   #7
My Ride: 87 Shelby Z
the 94-95 have the AX-15 which is also in the 3.9 V6 trucks. I would think that trans would be able to hold the power and abuse of towing for quite a while.
Benji
bfarroo is offline
Old 11-07-2006, 06:16 AM   #8
My Ride: 88 Shadow
Feedback: (6)
I have a 90' 2.5 5 speed, what tranny is that?
Old 11-07-2006, 07:14 AM   #9
I need a Bell Housing for a 94-95 Dakota 4 cylinder, anyone have one for sale?
mr_niteowl@nexicom.net
Thanks Earle
mr_niteowl is offline
Old 11-08-2006, 12:04 PM   #10
hell i use a 4cyl 1989 dakota to pull my 42' 3 place gooseneck car trailer around. (not for long trips but I've used it around the yard and to haul a couple cars 5 miles to the JY)
allmotor is offline
Old 12-18-2006, 04:09 PM   #11
My Ride: OMNI, ShelDak, TSi
Engine: 2.2 'GLHS style' TII
Feedback: (28)
I pulled my '86 omni 700+ miles on a tow dolly behind my '91 2.5-speed 2WD 3.92FDR dakota; did OK, and still got 15-17mpg; tough to go much faster than 65 or so ; I wouldnt want to pull *much* more than that for a long distance...
however crosswinds and slush on roads made it a tail-wagger :big eyes: pucker up!
I have also had 2000# of topsoil in same truck; there was NO suspension travel in back; rubber bump stops were mashed onto axle; that was *too* much weight; it will haul 1000# comfortably but much more than that and it is pretty much maxed (rated at 1250# which I think is a reasonable MAX)
detobias is offline
Credit Cards | McDonalds | Cheap Loan | Car Insurance | Buy PSP
Page generated in 0.36241 seconds with 13 queries
