Go Back   TurboDodge.Com - Turbo Dodge forum for Turbo Mopars, Shelbys, Daytona, SRT-4, PT Cruiser, Omni and more! > Turbo specific > RWD Turbo-Dodge
Old 01-01-2007, 01:15 PM   #1
chrysler conquest?
how difficult and what transmission could you run when installing a 2.2 or a 2.4 turbo? any thoughts? also is the rear end strong at all and what gears do they come with?
just8av8 is offline
Old 01-01-2007, 02:13 PM   #2
My Ride: 88 shelby z
i thought about this before wehn i had mine... trans im not sure.. im assuming a dakota trans??. i know someone out there makes aadapter to put a t56 6 speed in the conquest...
as far as rear end if i remeber right there goot to over 800 whp and stock have 342? gears.... a easy up grade is the gears from a d50 391's
4cfed is offline
Old 01-01-2007, 02:30 PM   #3
not bad. i think i might look into this further
just8av8 is offline
Old 01-01-2007, 02:42 PM   #4
i wish i could get a hold of the guy i bought a head and turbo from for my old quest.. he has a nasty nasty coqnuest and i think its for sale..well was last time i talked to him.... mr2 coil overs cobra r wheels, mpfi set up. with a hugh hugh ugh supra sized turbo!
4cfed is offline
Old 01-01-2007, 04:33 PM   #5
my sheetmetal intake gt35r lonewolf head ported built 2.2 might make it in one...that would be nice
just8av8 is offline
Old 01-22-2007, 09:19 AM   #6
I used a 2.2 dakota engine and transmission, custom make engine and trans mounts, custom drive shaft. stock conquest rear axle is 3.545:1. You cant use rear D50 gears... however you can use the gears from the front axle of a 4x4 d-50/raider etc. my quest now has 4.62:1 rear axle ratio which came from the front of a Raider.
allmotor is offline
Personal Loans | Remortgages | Loans | Online Loans | Free Ringtone
Page generated in 0.66064 seconds with 13 queries
