07-21-2007, 10:14 PM
#77
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
thanks larry, that seems simple enough to make.
i might either do that or see what i can find locally for cutting and rewelding. i wanna move mine in a little towards the strut too for more steering angle.
Brian
07-22-2007, 02:52 PM
#78
My Ride: No slicks Omni
Venolia 8.5-1, 2.2, .030" over running low 20's boost.
I was detonation free leading up to my failure, wasnt
watching the knock reading at the moment (pulling a
LS1 Z-28 at the track!) but the plugs looked great and
there was no sign of detonation on mine as well.
Not sure if my bent crank (machined just months earlier)
was a biproduct of the failure or cause. with the #1
and #4 bearing in and the caps off it was very noticable
on a dial indicator, visible wear on one side of the cast
crank. Used a Forged crank on next motor with no
problems for yrs, new owner still beating on it we spea.
07-24-2007, 11:00 PM
#79
My Ride: 89 turbo van 5-speed
Engine: 2.5 turbo
russ what kind of car was that in. I have a 2.5 in my van with a neon dohc and i have not had a hole lot of luck with it . any tips i should know. It has power up to 10 lbs and after that it pops . I want to to pul the motor and put a new block in it or just put in a 2.4 srt motor.
07-25-2007, 08:00 AM
#81
My Ride: '85 Dodge Daytona Z
Engine: 2.2L TI
KClarryb, I don't think it was mentioned enough times on this thread, but that is an amazing piece of work. Good job fabricating everything. You must have countless hours of welding on that beast. I am suprised you put the interior back in. I thought for sure it was going to be a drag car. I can't believe how stock it looks. A 12 sec street car....amazing.
10-22-2007, 01:01 AM
#85
Re: A few pics. of my RWD conversion parts
My Ride: '88 Shelby Z TII
That's a very nice car. I'm very impressed. I don't know how I missed it this whole time. Keep it up! I can't wait to see some videos of this thing cranking some awsome 1/4 miles passes and hearing the jaws hit the bleachers when it pulls the front wheels 6" off the ground!!!
12-01-2007, 11:54 PM
#86
Resident piston cracker
My Ride: 92gtc vert
Engine: 2.5 8v
Hey Larry, care to share more details on the actual engine, like which TB and FMIC you used, also the longblock build?
Come for a dyno run NEW Get-together 2-23-2008 @ 10am
http://www.turbododge.com/forums/f1/...-dyno-day.html
12-03-2007, 10:59 PM
#87
Hybrid Booster
Ford 4.6 SOHC throttlebody modified for the Chrysler TPS, no AIS motor.
2 core intercooler made with Ford supercharged Thunderbird intercoolers with 3" plumbing.
Long block: 89 2.5 CB,T2 rods with ARP bolts,Wiseco .030 pistons,97 2.0 DOHC Neon head with ARP studs and Fel-pro MLS head gasket,Geo Metro cam gears,Ford Taurus sparkplug wires,JGS log exhaust manifold,Holset HE351 turbo,and of course the oxygen bottle intake manifold,57lb injectors.
I spent approx. 1 hour grinding and sanding on the head nothing serious just a quick bowl cleanup (who knows I may have hurt the flow more than I helped)
Also picked up a set of the improved lifters and rockers out of a 2004 DOHC 2.4 (they were free so why not).
Also bumped the 2 oil drains in the head up to 3/4", used to have 1/2" in the front and 5/8" in the back.
What did this pile of mismatched parts get me besides a lot of fun putting them together?
I'm in the right lane on the timeslip and 25psi on the dyno.
12-03-2007, 11:31 PM
#88
My Ride: 1993 Iroc Daytona
Engine: 3.0 V6
Dude wow. Nice dyno runs
12-03-2007, 11:45 PM
#89
My Ride: 92gtc vert
Engine: 2.5 8v
Those are some very impressive results! You must have done something right to that head to get those numbers. They say that the stock srt4 heads flow the best, but you have proven that with very little work the 2.0 heads can make good power.Oh and the 2.0 heads have 2mm bigger exhaust valves. Btwy Mind if I copy your engine?
12-05-2007, 12:11 AM
#90
VERY nice results!! By the dyno chart that thing wants to keep pulling past 6K. I wonder what it would do if you let it spin a little more?
