05-17-2007, 07:44 PM
obvious you have a fuel issue based on your description. so you put in a new pump, maybe it's bad, maybe you need to return it for another... when you turn on the key, you should hear the pump run for a couple seconds. have you physically tested fuel pressure? have you verified power to the pump? checked the ground circuit at the pump? that's where I would start. then if you do indeed have a defective pump, you'll have some intellegent information for your proof of having a bad pump.
