Go Back   TurboDodge.Com - Turbo Dodge forum for Turbo Mopars, Shelbys, Daytona, SRT-4, PT Cruiser, Omni and more! > Turbo specific > RWD Turbo-Dodge
Old 08-13-2007, 11:35 AM   #16
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (20)
Originally Posted by RPMurph
what would you do about cooling?use air from up underneath of the car?
the radiator would be the same with some long arse pipes to the engine. Bleeding the cooler will be a pita tough.
I practice what I preach:
crazymadbastard is offline
Old 08-13-2007, 01:17 PM   #17
AC/DC rules!
itsbudda's Avatar
My Ride: 1987 Lebaron
Engine: 2.2L Turbo 1
Images: 30
well, i'd think that those long pipes to the engine from the rad would be a tad inefficient at cooling. But i couldn't imagine a better place to put it.
itsbudda is offline
Problem Mortgage | Mortgage Calculator | MPAA | Mortgage Calculator | Loans
Page generated in 0.36868 seconds with 13 queries
