07-23-2007, 11:01 PM
Mid Engine Daytona
AC/DC rules!
My Ride: 1987 Lebaron
Engine: 2.2L Turbo 1
Moving the Engine, tranny, and whatnot to the back. Is it possible? I know thats a step further than RWD. Has it been done?
07-23-2007, 11:10 PM
My Ride: Daytona Tubo Z C/S
Engine: 2.2 Turbo
Sure, it can be done if you have the time & ability to do the fab work. Search around.. there's been rear drive conversions, mid engine conversions, and even a couple twin engine setups.
07-24-2007, 12:52 AM
MEOW!
My Ride: lebaron
Engine: 2.2L TI(ish)
i'm going RWD with my omni. i am going to use a dekota trans(for temp. untill i get a adapter made for a 727) and i am using a 2.5L dekota block and putting good rods and pistons. and for a rear end i am using an A body (dart or duster or demon) so i dont have to cut a one(and it saves money for the motor!!) but on here i have seen a really nicly done shadow!!
07-24-2007, 07:05 AM
My Ride: Shelby Charger
Engine: 2.2 turbo II
This omni was for sale couple months back.
Planet B
Check them out.
07-24-2007, 09:54 PM
AC/DC rules!
Yeah thats a nice omni. I don't know. Is that more or less work than a tranny swap? Probably more. But definitely cheaper
07-24-2007, 11:46 PM
My Ride: 85 GLHT, 87 ShelbyZ
not much room in the back of a tona for an engine though. An Omni has a 2" longer wheel base and is more square so the motor isn't right near your head
07-25-2007, 01:52 AM
My Ride: 89 turbovan
Engine: 2.5 CB
ive seen a 2.2 t2 in the back of a crx once
08-09-2007, 01:23 PM
AC/DC rules!
what i would do if i did it would be to remove the hatch, and fab it to be similar to a mid 90's Toyota MR2. It could work.
08-10-2007, 09:07 PM
My Ride: '89 Daytona Shelby
Thought about this myself too. Pretty much had it all worked out in my head. One thing that is uncertain is the handling. I'll all fit ... pretty sure anyway. Might be a wheelie monster though. That would suck, major.
Don't know how or what formulas to get an idea of the leverage imposed (and limits) with the engine just forward of the rear wheels.
I'd still like to try it on a junker just for kicks though.
08-10-2007, 11:40 PM
My Ride: 91 Spirit,87 ShelbyZ
Engine: 2.5n/a, 2.2t2
Planet B
how would that thing ever pass inspection?
you could probly solve the problem of handing with changing around spring rates and strut stiffness and such to get a nice balance
08-11-2007, 11:48 AM
hehe no inspection here  a small firewall could be built easily enough. Look at the Renault Clio V6's.
08-13-2007, 10:46 AM
#12
AC/DC rules!
It'd be fun to drive. May have to weigh down the front for better traction
08-13-2007, 11:14 AM
#13
Resident piston cracker
My Ride: 92gtc vert
Engine: 2.5 8v
I had a Fiero GT v6 12yrs ago, that thing was fun. In the corners though, it used to "push" or understeer. I think we would have the same problem with mid engine daytona.
Come for a dyno run NEW Get-together 2-23-2008 @ 10am
http://www.turbododge.com/forums/f1/...-dyno-day.html
08-13-2007, 11:23 AM
#14
AC/DC rules!
maybe
08-13-2007, 11:24 AM
#15
move as many things under the hood as possible.....huge fuel tank, battery, spare tire
what would you do about cooling?use air from up underneath of the car?
