08-07-2007, 10:06 PM
Front tire ??
My Ride: Shelby Charger
Engine: 2.2 turbo II
On my arrow the front wheel and tire weight is just under the 30 lb mark. The current size is a 155 80 13 and looking at tire spec the tire should weight about 13-15 lbs leaving the steel wheel at about the same. Do you think it light enough? I'm asking since the rear are 26 11.5 15 on set of 15x 10 rims. They weight about 60 lbs each. Since there the drive wheels I think it will help in traction.
Or does anyone have a set of wheels in a 4 x 4.5 x 13 rim that lighter?
Car specs are 360 sb mopar, back half ladder bar setup, striped inside and out. rear end is a 8.25 narrowed 30 in with 3.23 gear the motor should be about 450 with the turbo or more.
Starting weight is 2100 lbs.
Check them out.
