Go Back   TurboDodge.Com - Turbo Dodge forum for Turbo Mopars, Shelbys, Daytona, SRT-4, PT Cruiser, Omni and more! > Turbo specific > RWD Turbo-Dodge
Old 02-20-2008, 11:24 PM   #1
gunna convert the daytona to rear wheel.... rear end opinions
My Ride: 91 Daytona
Engine: 2.4
so im going to start the rear wheel conversion, slowly, but im going to do it, first thing is to do is the rear end, with coilovers, so i dont have to do the suspension twice.
here are my options:
  • dana 44 from a jeep cherokee
  • ford 8.8
  • crysler 9.25
  • IRS 8.8/44/other
the dana 44 and 9.25 use a typical 1310/1350 u joint yoke..... the same ones that im having problems with in my cherokee, the cast ears break off, u joint cap spits out, and then the driveshaft hits everything under the jeep.... dunno if theres a fix for this, u joint u bolt straps may fix this
8.8 has a flat 4 bolt flange, fixes that..... but its made by ford, and a little narrow
IRS opens a can of worms, definatly doable, but trying to decide if its worth it, i dont know how much better it handles, but when working at mazda, the speed6, rx8 and miata were some of the best handling stock cars that ive ever driven, all IRS.....
opinions are definatly welcome, on my list, or feel free to add some of youre own
Rock Kustoms is offline
Old 02-20-2008, 11:37 PM   #2
Re: gunna convert the daytona to rear wheel.... rear end opinions
My Ride: 1985 &86 Omni glhts'
Engine: 2.5 T2
Images: 14
At the Woodward Dream-Cruise (in Mich.) a couple of years ago there was a '85 or'86 Red Daytona w/ a 340, a 904 auto. and a stock-width B-body 8 3/4 rear end. From the side all rims looked "normal" , as the rears had most of the off-set on the inside. Hard to tell it was V-8 RWD until he Booted-it!!
ol"blue is offline
Old 02-21-2008, 12:09 AM   #3
My Ride: 91 Daytona
Engine: 2.4
yeah, 8.75 is a nice axle, but, at $400-1200, not worth it IMO, the dana 44 and 9.25 i have, 8.8 $75, irs set up, prolly $150
Old 02-21-2008, 04:40 PM   #4
Hybrid Booster
My Ride: 1972 dodge colt
Engine: 2.4L
what gears does the 8.8 have ?That would be your best bet hold decent power with 5.0l's 9.1/4 little overkill,and i dont know much about the dana 44 but either way they will all have to be cut to fit,the datsun pick up truck rears are really stronge but you need to find an older one with the aluminum center section they come with 4.37 gears.
turbocolt2.4L is offline
Old 02-21-2008, 05:16 PM   #5
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (21)
I think 8.8 should be plenty stout and looks to be easy to find and mod. BTWY, you are crazy. that is all.
Winston
dyno sheet
fmic install:
crazymadbastard is online now
Old 02-22-2008, 12:03 AM   #6
My Ride: 91 Daytona
Engine: 2.4
all the axles i have are between 3.07 and 3.73, im not sure what ill end up w/ for gears
the 44, 8.8, and 9.25 are all within 1.5" (.75" per side) of stock width, so w/ wheelspacing thats all set
also what kinda limited slip/locker to run, all my jeeps i just spooled
Old 02-22-2008, 12:42 AM   #7
My Ride: '88 Shelby Z TII
Did you give up on trying to manually control the A604? If not, how far along did you get?
Reaper1 is offline
Old 02-22-2008, 07:28 AM   #8
My Ride: 93 R/t Daytona
5.0 8.8 rears come standard with 2.73, 3.08, or 3.27, or 3.55 ratios.....
snkmug is online now
Old 02-22-2008, 12:19 PM   #9
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (21)
If you can find I think a saleem or a turbo mustang or on, they had an aluminum rear 8.8 IIRC.
here is gobs of info on the 8.8:
The Ford 8.8 Mustang Rear End - Car Craft Magazine
dyno sheet
fmic install:
Old 02-22-2008, 07:32 PM   #10
My Ride: 91 Daytona
Engine: 2.4
i got the auto shifting fine with relays, full power, no issues, but i dont drive it much
Old 02-22-2008, 08:05 PM   #11
MEOW!
My Ride: 87shelby charger
Engine: 2.2L TII
Images: 150
you could use a 8 3/4 A body(dart demon duster) this way you can use small bolt and have stock wheels.
turbomini is offline
Old 02-22-2008, 11:15 PM   #12
Feedback: (22)
or i could deliver a 86 chrysler laser that has already been converted to rwd and a small block. Looking to get 1700 for it delivered (heading to ct in a week). Already has 8 3/4 suregrip rear along with built 904 with rmvb in it. Just needs your small block and is ready to go.
jason
j4278h is offline
Old 02-23-2008, 04:12 AM   #13
Rock, could you detail out what you did and how well it works to make it shift propperly(I'm assuming you got the 2/1 downshift to work also). I'd like some feedback on how well this idea works and what you would improve on, ect. I know this has nothing to do with this thread, so maybe the origional thread or a new one? Thanks!
Reaper1 is offline
Old 03-03-2008, 01:58 PM   #14
My Ride: 1981 Dodge Aries
Engine: 451 BB Mopar
BBKcar is offline
Old 03-21-2008, 10:42 PM   #15
My Ride: 91 Daytona
Engine: 2.4
PM me, or AIM me......
Loans | Mobile Phones | Credit Counseling | Loans | Mortgage Calculator
Page generated in 0.88146 seconds with 13 queries
