11-11-2006, 09:58 AM
#136
My Ride: 95 neon 2dr srt4 swp
Engine: 2,4l turbo
Originally Posted by boost geek
Here's my latest project, 2.2 / Ford C4 swap. Adapter plate is in progress...
Any progress on this one,sounds like a good idea
11-11-2006, 10:19 AM
#137
My Ride: 87 Shelby Charger
Surrey, eh! The adapter plate was in my friends shop, he went to P.E.I. for 3 weeks, got back but haven't seen him yet. His neighbour has 2 CNC machines, was gonna get him to mill 2 large holes, one for the 2.2 crank, one for the Ford starter. Progress has been slow, I'll try to get a hold of him today, he works night shift, should be up this afternoon.
01-05-2007, 09:47 PM
#142
Authorized TD Vendor
My Ride: 91 Spirit R/T
Engine: 2.2 TIII
Im pretty sure my buddy that drives a Datsun 280 said the Datsun Auto uses the same bell housing pattern as a Ford gear box. I can dbl check but its waas alot longer than 30 inches. His power glide is alot shorter.
Wallace
91 Spirit R/T
11.686@120.89 mph
01-06-2007, 01:06 AM
#143
My Ride: '87 Omni
Engine: Dodge 2.2
What about volkswagon transaxles, doh the engine is on the wrong side...
01-06-2007, 12:26 PM
#144
Not if you flip the ring gear. Formula V cars run with the engine in front of the transaxle.
01-08-2007, 08:53 PM
#146
01-16-2007, 11:44 PM
#148
My Ride: 1978 Dodge stepside.
Engine: 318 Turbo Project
Hey guys, I'm purchasing Nvr2Old's 77 SpitFire with the NV2500. I've read through this thread and have come to the conclusion that the only 5 speed that will actually fit into the 77 Spitfire is the NV2500 however I would like to upgrade. Is there an auto tranny out there that might be able to fit? Any idea on if a Turbo Supra Auto tranny will work? Thanks.
Michael
03-03-2007, 11:33 AM
#149
My Ride: Dodge shadow
i have 2 bellhousings one is a dakota a535 2.2 bell and other is a 03 jeep liberty/wrangler 2.4 bell... if anyone is interested in them let me know. speedy5131981@yahoo.com i played around with rwd conversion ideas. basically was going to use a turbo 2.2, the dak bell (5 1/8) center. Overdrive np833 trans (5 1/8 brng retainer) weld and redrill bellhousing then use turbo 2.2 flywheel and i believe 3.9 v6 clutch and pressure plate
04-15-2007, 09:36 PM
#150
Progress has been slooooow..., more focused on my alky kit now. I had the holes cut on a cnc machine, fits perfectly on the crank.
