01-06-2013, 12:55 PM
#35
Re: Ram 50 1988
Super Pope
the 05 up engine doesn't use a cable throttle and the computer system is a lot different to run it all. New engines make more power by working like a predator carburetor where they have variable CFM levels with engine load. So when you floor it you only get about 50% throttle till the engine revs up enough to get the rest of it. This makes for more torque and HP through out the whole RPM range.
As with any V8 the carb makes unreal power everywhere, too much really causing worlds of damage with a 440 lol. Also ate a ton of fuel even though it ran it lean enough to turn the headers red. But todays hemi's and the new V6 engines make a ton more power and torque from using this tech in electronic fuel injection form.
Going to this though you must use all the factory wiring or it won't work, you'll also have to include interior wiring.
In a PM you mentioned drifting and drag racing. Drifting with a little engine really sucks, you have an on off switch power wise. AE86 guys rip out the turbo 4 and add a Toyota V8 for instance. So you should move thoughts towards the new Hemi, not a V6 even with a turbo for drifting.
I grew up with muscle cars, so the idea of drifting as a sport is amusing. Unless you drive really slow or backing out of the driveway you really don't use the front wheels to turn. More like a motorcycle. Lean your head over to the side a bit and give it the gas and you turn. But you must be able to completely control tire speed with the throttle. Turbo's and electronic throttles murder this driving control. Today people look at drifting as reckless driving, trying to crash to do it. In the 80s with a muscle car if you didn't drift you were going to crash. Those cars don't turn unless you slow way down. So you either learned how to over steer all the time or you under steered into a ditch.
Drifting is dominated by V8s and the V10 Vipers, so it would be wise if looking at drifting NOT to run a little engine. Drag racing is different of course.
Rob Walsh
84 DC Shelby Rampage
86 GLHS 76
89 CSX 187
05 PT GT
93 Cummins
