Intake Routing - Turbo Dodge Forums : Turbo Dodge Forum for Turbo Mopars, Shelbys, Dodge Daytona, Dodge SRT-4, Chrysler PT Cruiser, Omni and more!
Mitsubishi V6 engines Discussion area for the 3.0 turbo and non-turbo
 2Likes
  • 1 Post By EvilcowRoland
post #1 of 10 Old 08-11-2016, 07:16 PM Thread Starter
My Ride: 1994 LeBaron
Intake Routing
I've been wondering how some of you guys route your intakes on your cars.
I need to build one for my LeBaron and I'd like to avoid relocating the battery to the trunk if I can help it.
Thanks!
OfficerJoseph is offline
post #2 of 10 Old 08-13-2016, 01:36 PM
TD Extreme User!
Re: Intake Routing
Under the battery. Moved and trimmed my stock battery tray back in the day
post #3 of 10 Old 09-01-2016, 09:19 AM
Re: Intake Routing
I have seen some people buy those smaller batteries and put them in the stock battry location and run their piping next to it. Somone did that here a while back but I think some have even hooked up a lawn mower battery with high cranking amps in the stock location.
mopar969 is offline
post #4 of 10 Old 09-02-2016, 10:10 AM
TD Extreme User!
My Ride: 90 Daytona Shelby
Images: 12
Re: Intake Routing
I ran mine in front of the battery with a small can-style filter and some 3.3 intake hose pieces. It pulled cold air from a hole behind the headlight, but the 90 degree bends are bad for airflow. Not sure it helped performance any by itself. I also went to the 52mm TB at this time. The net gain was a little better throttle response. Didn't really notice much other difference in the car in either performance or economy. It had a wicked sound when you mashed the throttle open though.
6g72 acclaim likes this.
-Brian
90 Daytona Shelby
96 Jeep XJ
EvilcowRoland is offline
post #5 of 10 Old 12-14-2016, 07:26 AM
CoupleOvans
6g72 acclaim's Avatar
My Ride: 94 Voyager
Re: Intake Routing
I feel like that's not a bad setup if you could hard pipe it. Either way, looks good.
6g72 acclaim is offline
post #6 of 10 Old 12-25-2016, 01:24 PM
Hybrid Booster
My Ride: 93 Duster
Engine: 3.0 V6 6G72
Induct: S/C
1/4: 14.620
Re: Intake Routing
I did a K&N RU-3030 right off the throttle body, but built a cold air BOX to enclose it. Had a 4" drier hose running from that to forward of the battery with some sheet metal to at least partially block off that area from the rest of the engine compartment.
Avenger is offline
post #7 of 10 Old 12-25-2016, 04:16 PM
Super Pope
The Pope's Avatar
Re: Intake Routing
the factory setup is a cold air and you can open it up to work better with a K&N. Doing this and putting the filter in the engine bay to suck boiling hot air isn't a great plan unless you live in North Dakota...
The Pope is offline
post #8 of 10 Old 12-25-2016, 05:39 PM
CoupleOvans
My Ride: 94 Voyager
Re: Intake Routing
Shorty on my car, my intake plenum would still be cold to touch after 1hr of sitting in traffic on a 90* day. That was filter sitting right behind the battery. The factory box sits almost on top of the rear exhaust manifold, with 2 almost 90* bends, combined with the 180* from the computer tube to the engine tube., I don't buy that the ambient air running a short ram is warmer than the air out of the factory intake.
My experience with both, especially in traffic, the short ram keeps the plenum cooler, which tells me the short ram pulls colder air than the factory intake.
94 Voyager: 3.0, 52mm tb, ported plenum, mild port heads, 2.5" catless exhaust, 2-toned, front dropped 2".
95 Voyager Sport: 3.3 V6: 58mm TB, spacer, CAI, 2.5" catless exhaust.
Brandon Contildes 5/13/85-1/20-2015
post #9 of 10 Old 01-03-2017, 12:47 PM
CoupleOvans
My Ride: 94 Voyager
Re: Intake Routing
Just run it like this, then attach it to a snorkel like this (obviously got rid of the cone, that was just until I got a new filter for the housing):
Then you'll never have a problem with cool, fresh air, or going through water
post #10 of 10 Old 01-10-2017, 10:37 AM
TD Extreme User!
Images: 12
Re: Intake Routing
Not on the 3.0 cars Pope. It's true that it pulls cold air in through the ECU like the turbos, but the airbox sits directly over the rear exhaust manifold. It gets very hot there and the air slows way down having to do a complete 180 turn to get back out. Moving the actual filter location to the front of the car helps. I agree that you don't want it sucking air in from the engine bay in general, hence why mine was pulling air from behind the headlight like the factory design. Getting rid of that airbox has the added benefit of giving better access to the rear plugs and wires too.
-Brian
90 Daytona Shelby
96 Jeep XJ
Human Verification
