Old 04-15-2006, 12:49 PM   #46
My Ride: 89 omni & 90 T1 shad
Engine: 2.5L HX-35 w/alcohol
also the 3.3s have a ton more wiring and stuff dont they? not fun for someone like me thinking about stuffing one into an omni. again though, how are you guys adding fuel? and what kind of boost are you running in them?
turbo minivan is offline
Old 04-15-2006, 02:18 PM   #47
Have fun playing with the direct ignition. Not adjustable I believe.
Old 04-17-2006, 06:36 AM   #48
Originally Posted by Reaper1
The 3.3 CAN be made to have power, but with the limited ways in which it can be delivered to the ground(A604 only)...my question is....WHY?
I have never tried it, but I think there is a manual trans that will fit a 3.3L. Came in a very limited number of 5-sp equiped Stratus R/T's....
Edward Kelly
Kelly-Mulhern Performance
www.kmperformance.com
c2xejk is offline
Old 04-17-2006, 05:57 PM   #49
Good luck finding one...
Ntrain2k is offline
Old 04-21-2006, 03:19 PM   #50
im still wondering about how your adding fuel to these things under boost.
also, MAP sensors? 2 bar? ?????
Old 04-21-2006, 05:50 PM   #51
My Ride: 89 Shelby Daytona
Engine: 2.2L T2
adding fuel by installing 33# injectors inplace of the 19# stockers and a Vortech Super FMU that holds base pressure as well as adds pressure per lb of boost.
I left the map sensor alone and it ran fine.
Harvii is offline
Old 04-21-2006, 08:52 PM   #52
My Ride: 1993 dodge daytona
Induct: S/C
hey ondonti, is that a pic of your turbo 3.0 on the first page? did you say you may run mid 12's on 5psi? i would like to see some numbers like that when i am done! hey what did you do about an ecu? also, what fmu are you using? i have a vortech sfmu which i think should work good. do you have a home page for that car? also, what size injectors are you using? i want somewhere between 350-400whp when i get done so i was thinking of 38lb injectors?
m90daytona is offline
Old 04-21-2006, 10:05 PM   #53
I ran a 13.9@101.89 on 5 psi boost. Faster then an srt-4 in the traps.
The new setup should run 12's at sea level @ 5psi.
Old 04-21-2006, 10:17 PM   #54
Induct: S/C
so whats your fuel and ecu set-up or is it top secret?
Old 04-22-2006, 02:00 PM   #55
at the time it was stock ecu and a rising rate regulator on 30# injectors.
Dont ever boost a 3.0 on a stock fuel pump btw.
I have a megasquirt 2 sitting in my room but its not getting hooked up anytime soon.
Old 04-22-2006, 02:20 PM   #56
Induct: S/C
i have the walbro 255 l/ph fabricated in my sending unit. it was made for the turbo chryslers but i made it work w/ my application. what is the megasquirt 2? is it an inline pump or does it bolt right into the stock sending unit?
Old 04-22-2006, 06:06 PM   #57
The megasquirt 2 is a Stand alone engine management system replaces your ECU and is completely programable
Jetson8294 is offline
Old 04-22-2006, 09:51 PM   #58
Ive got a walbro 255 High pressure sitting on a shelf in my room. Im busy finishing the chassis right now and the gas tank just gets in the way.
Old 04-29-2006, 08:05 PM   #59
i just picked up a nice 3.0 the other day! yeehaw!!! here we go twin mitsus!!!
then ill just need to find a cheap omni. =)
Old 05-18-2006, 05:12 PM   #60
Wrong car/motor (wanted to see what it will look like) but I think its sexy.
Jokes | News |
