Old 07-17-2006, 04:07 PM   #121
your last paragraph has 2 questions in it (2 different projects).
Im not sure what you are asking. #1 seems to be about a supercharger, #2 doesnt make a lot of sense. Heat is just something you are going to have to deal with. There is no magic trick that will make heat ONLY be your friend
Small turbo = more heat. Your exhaust temperatures are not going to change as long as you are out of boost though. Higher temps generally come because you are burning more fuel.
I dont believe you can coat the wheel, and realistically, if you coat the housing, the coating is going to get worn off by the turbine blade where they come close to each other. There are some efficiency gains but I think the $ would be better spent on a nicer turbo or better gauges or left in your pocket, etc.
You arent going to see gains from this kinda stuff unless 5 hp in a 500hp motor is a big deal to you.
The biggest "efficiency" gain you will find is using a larger turbo. Larger turbo just meaning pick the turbo that will make the HP goal you have. Probably ported heads will help some, as well as different cams. Both of those would cost the same as doing all that coating, and have much larger gains.
If you dont have a HP goal, then you need to figure one out. there are some turbos which are just too small for our motor no matter how low your goal is. There is a guy who just put a 16g on. That is decent for 350whp goals. Now if you have a 350whp goal and you want to use a 9b mitsubishi turbo, you will never make even 200whp with that turbo.
Get a power goal, then go on franks turbo calculator at turbomopar.com......try some stuff out on there, then maybe ask people when they think your specific turbo choice would start spooling on our motor. Then you can get more realistic #'s. I already had my turbo car running so i knew what RPM I was getting what boost. That made the calculator very easy to use for me. I did find that I picked the wrong turbo (my first turbo) though. Too much exhaust turbine.
Old 07-17-2006, 07:29 PM   #122
I was trying to ask if a SC dumps less heat into the engine bay. I think they must be cooler. But I asked just in case that isn't so. The more fuel means more heat rule applies though surely.
That makes sense. I didn't think of that though.
hmmmm Now that my engine gets only outside air from the cowl induction. I noticed my valve covers get a little hotter and my heat dissipate coated intake parts radiate more heat. I was afraid it was running slightly hotter because it is running lean. I hope I can trust that darn autometer A/F gauge. It doesn't show as much green as it used to, on the scan cycle anymore, but it still pegs all green at WOT.
Good to know. Thanks for the clue on that. Call me crazy but I just don't want a 1400-1700 deg F turbo under my hood. Since coating them wont work. I don't want one. Yeah. Just plain nuts. I know.
Come valve job time I will just get my heads done. Maybe add a Diamonte cam. My 41Te wont handle big HP anyway, and I already spent lots of money getting it race rebuilt.
Thanks for the help Ondonti.
Well since this is the case there is really no reason for me to be here. Rejoice Ntrain2K, and all you others who hate my ass too.
NA2ndgen is offline
Old 07-17-2006, 09:30 PM   #123
I do not hate you. I do thank you for taking the "stabs" out of your posts. When you ask questions without prejudice everything works better. See the replies you are getting now that everyone seems to be getting along better?
Ntrain2k is offline
Loan | Mortgages | Online Loans | Bad Credit Mortgages | Best Credit Cards
Page generated in 0.29897 seconds with 13 queries
