03-12-2006, 10:40 PM
Photos of turbo 3.0 setups
My Ride: '92 Lebaron GTC
Engine: 3.0L V-6
Hey, I wanna see what turbo 3.0 projects have been completed sucessfully or otherwise. I want to eventually piece together my own turbo 3.0 setup with around 10psi of boost.
Some nice setups i've seen and am envious of.
-Steve Reject.
03-13-2006, 10:31 AM
My Ride: 1992 Spirit R/T
Engine: 2.2 16v TIII
Who's car is the second one. I'm so tempted to repeat that in my GF's engine bay when she isn't looking.
Her low mileage 3.0 and long 3 speed trans are just dying to spool a little turbo.
03-13-2006, 12:01 PM
My Ride: 88 Plymouth Voyager
Engine: Mitsubishi 3.0
I'm still awaiting a V6 turbo setup in a mini.
Anyone???
03-13-2006, 03:36 PM
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
That one is Brent's. Or otherwise known as Ondonti here on the borads.
03-13-2006, 10:16 PM
wow that one is so sexy, but that turbo is tiny. Good thing Im upgrading.
03-13-2006, 10:25 PM
Engine: 3.0L V6
I'm wondering if they'll move all the turbo 3.0L info over to this area now?
03-13-2006, 10:53 PM
probably not, but that would be nice. The info is soooo spread out.
03-14-2006, 12:36 AM
My Ride: 93 LeBaron sedan
wow, that one is set up nicely, but needs a bigger turbo, this is nice that we now have our own little section
03-14-2006, 08:52 AM
My Ride: 1994 Dodge Shadow
Engine: 3.0 6G72
here's my never-ending turbo project. once i stopping running into walls, it'll get finished. lol!
[img]http://www.****************/forums/photopost/data/500/229772_154_full.jpg[/img]
it's using a ford turbo.
03-14-2006, 08:58 AM
My Ride: 93 Sundance Duster
Engine: 3.0L V-6
SWEET! I hope to see you at milan when you get it done. What car is that turbo from?
_____________
Josh
93 Sundance Duster: 3.0L A543 - 14.345 @ 93.77
95 Spirit: 3.0L A670
90 Shelby Daytona: 2.2 VNT A568
03-14-2006, 02:31 PM
#12
My Ride: 1993 Iroc Daytona
Engine: 3.0 V6
How did you do the rear manifold on your Shadow? I noticed you have it all wrapped so its sort of hard to tell?
03-14-2006, 02:51 PM
#13
Engine: 3.0 6G72
the rear manifold is custom made. pretty much looks like the front manifold (log type). the turbo is mounted from the crossover pipe. the turbo itself is a t3 from a ford, probably a turbocoupe. (60 a/r on the compressor side, 48 a/r on the exhaust side...for now..)
03-14-2006, 05:36 PM
#14
Engine: 3.0L V6
YIKES!!!!!!!
That turbo will just about boost at idle!!!!!!!
I have found that the 60 trim compressor of the T3 is bearly enough for a stock motor. You will find that it will be loosing power right around 4500-5000 rpms. But using the .48 A/R turbine housing will choke out the exhaust qicker than that. I recommend getting a .63 A/R housing at the very least.
Both Brent and I agree that a T3/T4 hybrid would be the ideal choice on a stock 3.0L motor. Preferably a 50 trim mated to a stage II or III turbine wheel/housing.
But don't take this as "Gospel", since I'm going with two smaller turbos for my project.
Wink
03-14-2006, 05:44 PM
#15
My Ride: TIII R/T
Engine: 2.2L TURBO III
nobody posted a pic of Dy-Nasty's 3.3L turbo, thats set up if sick
