03-17-2006, 01:17 AM
#22
Also, I think you guys are not understanding the low end power loss. Its really not noticable at all in a 5 speed car. Fact is that the increase in top end probably tricks you into thinking you lost bottom end.
I can pull 1st through 4th gear from 700 rpms, and I can drive 5th gear at 1000 rpms all day long. You just need to realise that NO car is going to pull hard from 1000 rpms in 5th gear.....just like your car wont pull hard at 5000 rpms in 5th gear either.
BTW, My n/a 3.0 has a fully ported plenum, Ported 58mm tb (mines actually 58mm unlike your 55mm) and I have a full 3 " exhaust. Pretty sure no one else is running a setup that comes near as mine in killing low end power, and what would you know, I still have gobs of low end. Even running open manifolds.
On the dyno, the 3.0 gains big torque on the low end over stock.
