03-14-2006, 04:55 PM
V-6 intake modifications
My Ride: 1993 Dodge Shadow ES
Engine: 3.0 V6
I got a 1989 intake manifold assembly out of a 224,000 mile minivan. I plan to port the upper part of the intake (that the throttle body bolts to).
I've seen the sites that show to cut the center divider out completely, and I'll do that. But inside the intake top, it has cast in lines or bumps that go in different directions.
Should I smooth those down some also? I wonder how much effect they have on anything. They had to be put there for a reason. I'm using a 52mm throttle body with it also.
Also, using the intake upper half to lower half gaskets as a pattern, I was thinking of getting 2 spacers cut out of 1/2" plywood. I know plywood has been used as a spacer on 1960's / 1970's V-8's to keep heat away, and I've read how these spacers help the airflow turn in the V-6 intake.
Ideas, thoughts, comments?
