Old 03-20-2006, 02:35 PM   #1
Intake manifolds
My Ride: 89 Spirit ES 3.0
Engine: NA 3.0
Some food for thought. I was just looking st some mitsu motor info. I noticed that the 2.5 used in the Sebring / Avenger / Breeze / Stratus is a variant of the 3.0. Do the intake manfolds interchange? What other intake manifolds would physically fit out 3.0?
I'm just reading here:
http://en.wikipedia.org/wiki/Mitsubishi_6G7x_engine
87turbodance is offline
Old 03-20-2006, 04:59 PM   #2
it must be a sohc 12 valve intake.
Old 03-20-2006, 06:32 PM   #3
Engine: NA 3.0
What cars came with the 12V SOHC 3.0's that have a different intake then the chrysler variant?
Old 03-20-2006, 07:17 PM   #4
Diamante, sigma, montero.
The 2.0 sohc motors would probably work too but I doubt any are in the US.
Old 03-21-2006, 09:39 AM   #5
Engine: NA 3.0
I've been trying to look through the yahoo group on this stuff but there are so many posts it tedious. Are there any other bolt on cylinder heads or are we stuck with the stock ones? I'm picking up an '89 Spirit ES 3.0 this week and I'm just doing some research.
Old 03-21-2006, 04:51 PM   #6
My Ride: 93 Dodge Daytona ES
Engine: 3.0L MMC V-6
There are no real upgrade heads to the heads we have... while others will theoretically mount to the engine, in reality, there are many problems...
SOHC and DOHC 24V engines are both DIS as well as having a different timing setup...
3rdGen3.0 is offline
Old 03-21-2006, 07:00 PM   #7
Engine: NA 3.0
I have no concerns with DIS or timing setup as I plan to run megasquirt. What heads physically bolt on and function mechanically?
Old 03-22-2006, 11:42 PM   #8
Still don't think timing will work quite right... and water jackets are slightly different... if you're going to go through the trouble, swap in a dohc engine...
Old 03-23-2006, 02:46 PM   #9
You guys need to remember the biggest problem is the accesories wont bolt up even if you use the whole dohc motor.
You cant run the dohc timing tensioner on the sohc block either so a headswap doesnt really work.......
Old 03-23-2006, 03:56 PM   #10
Engine: NA 3.0
Well I guess I'll be welding up a dual plenum intake with a pair of ~40mm tb's. As far as the heads go. Can they be ported much? I'm pretty sure I've seen some pics of Ondonti's heads ported. Did you lose much bottom end power?
Wire Transfer | Personal Loans | Holiday Deals | Car Credit | Flights
1320drag - Drag Racing resource Nissan 240 Forum Audi Forum My Chemical Romance Forum BonneVille Forum Chevrole Forum Camaro Forum Car Audio Forum Car Video Forum Canadian Mutsang Forum Dodge Intrepid Forum Emma Watson Fan Site GM Forum Tuner news GT cars Honda Forum Jeep Forum Mazda Miata Forum RC Forum Mustang Forum Dodge Forum Zero Hurtz
Page generated in 0.38633 seconds with 13 queries
