03-26-2006, 08:13 PM
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
Don't bother with the Montero cams. They have the exact specs as the Chrysler 3.0L units. The only true "factory upgrade" is to use the FWD 3.0L Mitsy cams. The Diamante units have increased overlap/duration on the exhaust lobes.
As for beefing up the 3.0L...... It doesn't really need beefing up. The connecting rods are the same as the Twin Turbo rods in the Stealth/3000GT's. The pistons are cast, and are as good as you'll need for anything not using boost. But if you are going for boost, don't go over 13 psi of boost with the cast units. Even then, the slightest bit of detonation will start to crack them. These motors have been proven to hold up to 13 psi with superchargers without issues. However, I'd recommend using forged pistons, due to their ability to handle a few cycles of detonation better than the cast units can.
Heads.... If you can afford to have your motor out of commission while you have your heads worked on at a machine shop, then this would be the least expensive way to go. Or you can have your heads swapped out at a rebuilders shop. Choice is yours.
Good luck,
Wink
