Old 03-31-2006, 10:34 PM   #1
Newly ported Plenum
I was wondering since i just got done porting my plenum, how much power increase is average for that? i have a 52 TB, HUGE(6" diameter, 10" long) air filter. and a 2" straight pipe. oh and its a 5spd as well.
Jetson8294 is offline
Old 04-02-2006, 08:04 PM   #2
92lebaronGTC's Avatar
My Ride: '92 Lebaron GTC
Engine: 3.0L V-6
Images: 30
I've heard of gains of 5-10hp in higher rpms depending how much you gutted out of the plenum. It's a definate noticable increase.
-Steve Reject.
92lebaronGTC is offline
Old 04-02-2006, 11:59 PM   #3
everything is gutted and smooth enough where it feels like polished aluminum
Old 04-03-2006, 10:26 PM   #4
My Ride: 93 Dodge Daytona ES
Engine: 3.0L MMC V-6
polished? bye bye turbulence...
may want to roughen it up some... some turbulence is good... or is that only in the valves?
3rdGen3.0 is offline
Old 04-03-2006, 10:47 PM   #5
My Ride: 93 LeBaron sedan
some turbulence is good, thats why ppl losesome bottom end when they port out.
Boogieman142 is offline
Old 04-08-2006, 11:13 PM   #6
My Ride: '89 2.5 Turbo Spirit
Engine: 2.5 Turbo
I don't see how having turbulence in a dry intake manifold would make any difference. Moving air is moving air, there's no fuel to keep mixed up in it.
I've got my intake machined and the corners rounded out with carbide cutters and sanding drums, and the 52 mm throttle body is on also. After I get some totally stock 1/4 mile numbers in my '93 Shadow ES V6 / 604, I'll start "improving" it!
Tim_K is offline
Old 04-09-2006, 01:01 AM   #7
I think that has more to do with changine VE...
When you make less restrictions in the intake, the air comes in with less resistance, but the air is also less dense at the same rpm of the unported plenum... this lowers VE, which lowers torque... but you gain VE up higher in the rev band, which increases torque (which increases hp) up high...
Old 04-09-2006, 10:57 AM   #8
You only need a minor bit of turbulence in the intake port of the head.
Ntrain2k is offline
Old 04-09-2006, 10:58 AM   #9
It's not that you lose bottom end, it shifts the whole power band up a bit higher. We have a load of bottom end stock as it is. I gladly traded off some of that bottom end for the extra power up top.
Ntrain2k is offline
Old 04-09-2006, 02:13 PM   #10
That made no sense.
Old 04-09-2006, 02:49 PM   #11
Yep that made no sense at all
DKKNE is offline
Auto Loans | Loans | Personal Loans | Mortgage | Credit Card Debt Consolidation
Page generated in 0.35973 seconds with 13 queries
