Old 04-19-2006, 10:50 PM   #1
hey newbie here...there are others!
My Ride: 1993 dodge daytona
Induct: S/C
man i thought i was the only one interested in boosting my chrysler sohc 3.0! sweet forum! anyway, check out my cardomainhttp://www.cardomain.com/ride/2066425
this eaton m90 is re-geared and has a titanium shaft as well as the smallest pulley possible w/ out having to grind the nose away. it has also been heavily ported and is good to 25psi w/out case distortion. the guy i got it off of though says he ran 30psi on it once but thats just to much if you ask me. i am hoping to get this project done by late spring so i will keep everyone informed of my progress if you are interested.
m90daytona is offline
Old 04-19-2006, 10:57 PM   #2
My Ride: 93 LeBaron sedan
yeah good one, this is my m90
but because this happened
it now lookslike this
By the way is ur alt in the front of the engine now?
Boogieman142 is offline
Old 04-19-2006, 11:06 PM   #3
Induct: S/C
yeah...removed the a/c and made a bracket for the alternator. a/c never worked anyway and i wanted to get rid of some weight. i also have a brand new forged crank from a TT 3000gt, pauter rods, a heavily ported intake manifold, a 5spd trans w/ 350 gears and phantom grip extreme LSD, huge turboworks intercooler, etc...i will post some pics if you want.
nice body work btw...that acclaim cleaned up nice!
Old 04-19-2006, 11:28 PM   #4
My Ride: 93 Dodge Daytona ES
Engine: 3.0L MMC V-6
*snickers*
needs moar obx
3rdGen3.0 is offline
Old 04-19-2006, 11:36 PM   #5
Yes pics would be great. Yeah, my a/c still works so i am trying to find a way to keep it but still use the sc. I have a 3.77 543, lower gear ratio=more accelleration. bty, that pic is a little outdated, it does have the door on it now. I haven't done much body work to though, mostly on the door and door sill. sorry to disappoint you but its a lebaron.
Old 04-20-2006, 01:58 AM   #6
You hurt yourself by putting that forged crang from a 3000GT in there... you just increased weight... the stock cast crankshaft can handle up to 1100hp i beleive PLEASE CORRECT IF I AM WRONG
Jetson8294 is offline
Old 04-20-2006, 08:20 AM   #7
Induct: S/C
a lebaron...thats even better! some pics...
right now i am doing a new water pump and timing belt. next i am going to start an aftermaket ecu. i was going to go with the perfect power piggyback but i was wondering if there was a way to change the programming in my stock ecu? i should probaly visit the d-cal forum and ask them.
Old 04-20-2006, 10:46 AM   #8
My Ride: 89 Shelby Daytona
Engine: 2.2L T2
Awsome deal man. Heres what I made for my '90 Lebaron Drop top
Harvii is offline
Old 04-20-2006, 02:44 PM   #9
Induct: S/C
sweet...hey are you the first one to do this? also, is you s/c on upside-down? mine is going to be mounted regular. what was the benefit of that? also, how much hp can i push before i blow the motor and waht is likely to blow up? i was thinking the rods or the pistons where the weakest link but i am not sure. maybe the bearings or the valve springs are?
Old 04-20-2006, 04:30 PM   #10
get forged pistons... the cast ones are made to be lightweight and are quite thin with very little skirt...
Old 04-20-2006, 05:37 PM   #11
Induct: S/C
who makes forged pistons...wiseco? ross racing?
Old 04-20-2006, 07:36 PM   #12
Wiseco does, i know that, u can re-program the ecu, you will need to socket the e-prom and get a cable to attach to it. There is some info on the chrysler3litrev6 site, also if u can get any info out of him, thalk to nick boers, he is the one who started it i believe, he never finished it though.
Old 04-20-2006, 07:37 PM   #13
The pistons are usually the weakest link
Old 04-20-2006, 09:03 PM   #14
You cannot reprogram the ECU in the 3.0 application yet. No one has deciphered the code enough.
Ntrain2k is offline
Old 04-20-2006, 09:48 PM   #15
Induct: S/C
thats okay, i think i want an aftermarket one anyway so that i can mess w/ my ignition timing and data log also.
Page generated in 0.28946 seconds with 9 queries
