Well I went out to seat the rings (only driving uphill so I could roll the car home if needed) and when i got back, the crankcase vent that I installed had blown off. I think the rubber didnt like the temperatures cause it was very very pliable (it normally is not). So I will have to get some better hose from a Evco hose of hose. I use good hose for my oil drain and I guess this one doesnt like what I did.
Still, if its blowing off, that means there is a lot of crankcase pressure. This was only with 6 pounds of boost and I wasnt really going WOT to avoid overheating the cylinders and glazing. Just loading it up and part throttle boosting and decel. I hit WOT just a couple times and only for a moment.
Edit: the connection to the oil pan almost fell off too. I will have to be creative now. Maybe just tack weld a small lip around most of that fitting. The fitting is smaller at the end so its hard to get a good clamp load on there. It just wants to slide off. Seems rediculous that there is that much pressure though. I a large bump/dip and maybe that jumbled things that were loose because of then hot "melty" hose. I guess I will find out. i will probably hook my boost sensor up to the front manifold and test actual pressure in the block. I am doing too much guesswork.
I did a fun "part throttle" powershift with maybe 1 pound of boost. It was pretty dang fun. Just wanted to see if my practice was working. That clutch grabs! Tires broke loose on the part throttle shift just because of how nasty the clutch is
So shifting like that on the street is pointless (especially if I tried WOT shifting) but on the track maybe it will work. Dang fun still. Trans seems to be shifting real smooth so I think it wants me to break it some more
If I can get that vent to stay on, then I will.
