03-13-2009, 05:12 AM
#1681
Originally Posted by Reaper1
Interesting. I don't know what that really proves for the TD applications or your though. Honestly, that could be jsut that particular design. True, I'm going with the bennefit of the doubt, devil's advocate here, but I don't think you can pigeon hole a company's product based on ONE test! If that were the case NONE of use would be driving Dodges!! LOL
Plenty of high power TD guys have used these HG's with success. It may be true that it has something to do with the inherant design of the block and such.
I suppose that's why there's different options out there.
I agree with you though...if you are going to go o-ring, then do it to the block, NOT your heads! This is a pain, and expensive. It WILL require the propper HG. Contrary to some people's beleife you do NOT need a receiver groove in the head if the wire is the propper size...which should be determined by the machinist. If you do go o-ring, I'd dump the MLS and go to dead soft copper with inpregnated o-rings around the oil and coolant holes. Expensive, but they DO work!
One last thing....the spray sealant MOPAR uses on the MLS 2.0/2.4 HG's is NOT copper spray. I'm not 100% on what it is, but I do know that without it those things do NOT seal for crap! It HAS to be used! Maybe something to look in to before you go o-ringing and stuff!
On Copper headgaskets that are O ringed you are supposed to use freaking expensive Hylomar gasket spray.
The .004" steel ring is perfect for steel to steel gasket from what i know.
I was looking at old pictures I have of the Cometic and it has no fire ring at all. Just a funny v shaped indent around each cylinder in the thin metal top and bottom layers. The Evo gasket looks better then what we have.
You remember our oil steel 3.0 intake and exhaust gaskets? they were MLS...and thats pretty much all the cometic is. 5 layers of flat metal.
I think its a matter of companies thinking we don't need real parts and that we are just buying them because of the name, not because we have actual performance goals. Someone else got screwed by SCE headgasket company. Even Cometic has been talked to about their headgaskets and they say "oh well it works on our shop car" Which we all know doesn't exist.
Do you think its possible to bore a 93mm copper gasket to 94mm? (for future reference).
