Old 07-29-2006, 10:08 AM   #196
Good luck Ondonti. I hope you get it fixed soon.
NA2ndgen is offline
Old 07-29-2006, 12:45 PM   #197
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
I simply drilled mine out.. Using a drill bit that was the exact right size.. Once it's out, it's easy to replace.
Una is offline
Old 07-29-2006, 02:07 PM   #198
Do you have to removed the head to do that job?
NA2ndgen is offline
Old 07-29-2006, 02:37 PM   #199
Una
Engine: 2.5L Turbo
Nope.. Definitely didn't pull the head.. Right angle drill is your friend.
Una is offline
Old 07-29-2006, 03:50 PM   #200
Thanks Una.
NA2ndgen is offline
Old 07-29-2006, 06:00 PM   #201
I dont know where to get another pin. They look like hardened steel.
Old 07-29-2006, 08:42 PM   #202
Una
Engine: 2.5L Turbo
hehe.. I helped a friend fix his Neon when this happend.. Figure out what size the pin is, in his case we still had the piece that was trapped in his cam gear, we took it over to my drill index and figured out which hole it fit in, 5/16" if I remember right. Then I took the drill bit that came out of that spot in the index, figured out about how long the stock pin should have been, and chucked up that much of the bottom of the drillbit in my vise. Grabbed a hammer, and WHACK.. Snapped off the drillbit flush with the vise. Boom, new hardened steel pin.. hehe..
Una is offline
Old 07-29-2006, 08:43 PM   #203
I need some drillbits now :P
Old 07-29-2006, 09:33 PM   #204
Una
Engine: 2.5L Turbo
Wal-Mart..
Una is offline
Old 07-29-2006, 10:33 PM   #205
Im gonna play around and see if I can replace the pin without removing the cam.
The pin got destroyed hehe.
Old 07-30-2006, 08:50 AM   #206
Ouch!
Ntrain2k is offline
Old 07-30-2006, 05:58 PM   #207
Pin is a LOT longer then it looks in the picture.
I still need to fix up the pin a little bit. It is flared out a bit from when I hammered it in. Then I need to cut the end off since it is a bit too long.
Old 07-30-2006, 06:01 PM   #208
Una
Engine: 2.5L Turbo
You sure it's too long? It needs to stick out into the sprocket some.. Use a drillbit like I suggested?
Una is offline
Old 07-30-2006, 06:04 PM   #209
It is a LOT longer then it looks in the picture.
It is too long. He has to go throught he sprocket which is very skinny on a 3.0, and t hrough a washer. It cant go past the washer or the bolt will not go down.
Used a drillbit. My DSM buddy says he has done the same trick before.
Old 07-31-2006, 08:01 PM   #210
Bump for an update!
Ntrain2k is offline
Pay Day Loans | Loans | Mobile Phone | Personal Loans | Credit Cards
