Old 08-03-2006, 07:43 PM   #241
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Originally Posted by Ondonti
That is not the point
With the ignition on:
I dont get any voltage when I plug it in. Doesnt matter what the computer is seeing. I get 5v at the power wire before I plug it in. When I plug it in, I get nothing on the power wire. Moving the throttle does nothing since there is no power to begin with.
The sensor is FINE. NOTHING wrong with it. I have used both on my spirit last night. both have the same problem on the duster.
I agree, something in your wiring must be causing this problem, maybe a bad connection, or the pins are wired up in the wrong orientation.
Una is offline
Old 08-03-2006, 07:56 PM   #242
The ECU supplies the 5 volts for the sensors...
Edward Kelly
Kelly-Mulhern Performance
www.kmperformance.com
c2xejk is offline
Old 08-03-2006, 08:00 PM   #243
My Ride: 1993 dodge daytona
Induct: S/C
oh...well you can still ohm check the wiring and sensor
m90daytona is offline
Old 08-04-2006, 11:48 AM   #244
My Ride: '88 Shelby Z TII
It sounds to me like a flakey connection at the terminal....possibly inside the plug.
One other thing to consider is that the 5V reference from the computer is spliced a few times in the factory harness....it could be a failing splice getting overloaded by actually having to pass some amperage....just something to think about
Reaper1 is offline
Old 08-04-2006, 05:01 PM   #245
This is wrong, I need to retest..........................
OKay, I just did some more testing.
The map sensor on the Duster seems fine.
I did some testing on the tps plug, comparing what I read on the 3 terminals on the spirit and the 3 on the duster.
I did other tests, but this was the most helpful
There is a power wire, a signal wire, and a signal ground wire.
From positive battery
On the spirit I read 6.8V on the power, 6.0 on the signal, and 11.98 on the signal ground
From Negative
On the spirit I read 5.00v on the power, 4.5 on the signal, and 0.0 on the signal ground
From postive battery
On the duster, I read 11.98 on the power, 6.0 on the signal, and 0.0 on the signal ground.
From Negative
On the duster, I read 0.0 on the power, 4.5 on the signal, and 0.0 on the signal ground.
both tests I had the TPS unplugged and the MAP plugged in. Ignition on.
Old 08-04-2006, 05:04 PM   #246
I guess it would help if the FSM knew there was such a thing as a 3.0 in 1992 p bodies. I ahve to use AA body diagrams for the 3.0 stuff.
Old 08-04-2006, 05:14 PM   #247
Una
Engine: 2.5L Turbo
That's just weird as hell. Wire colors were standard between everything before 1990..
Una is offline
Old 08-04-2006, 05:26 PM   #248
Brent, can we get you to make a video of you doing the voltage test?
Edward Kelly
c2xejk is offline
Old 08-04-2006, 05:45 PM   #249
Well From what I tested, Im assuming the white/violet wire that powers the MAP does not get spliced to the white/violet wire on the TPS. Since the Splice is a pain to get at, I am going to just add another splice in a better location to fix that problem.
Still gotta find out about the grounding wire.
Old 08-04-2006, 05:50 PM   #250
My Ride: 1993 Dodge Shadow ES
Engine: 3.0 V6
If you have 5 volts at the TPS connector, then plug it in and get 0 volts, you may have an internally broken wire. Inside the insulation.
Tim_K is offline
Old 08-04-2006, 05:58 PM   #251
Fixing a wire that I broke the solder connection off of............Then i will mess with the white/violet wire again. I found the original splice. I dont have power there though because I busted a connection on one of my fusable link fixes.
Old 08-04-2006, 06:22 PM   #252
Okay, to try to fix it, i am doing this.
Found the splice.........
After the splice (A6) I still have 5 volts on the white/violet wire leading to the TPS. Somewhere in the main harness that disapears......so I am going to just clip that wire where I still have 5v, and lead it directly to the TPS. Then I will just need to find out the grounding problem on the black/blue wire.
Old 08-04-2006, 07:14 PM   #253
Found the grounding problem!!!!
The ground wire on the grey 18 (or whatever) pin connector which is black/blue does not have another wire on the engine bay harness side.......so it is not grounding to anything.
Old 08-04-2006, 07:38 PM   #254
I havent finished fixing the ground wire.......but I did find it. For some reason it connects to the stater 19 pin connector instead of the engine bay harness. Im just about finished splicing a new ground for myself.
Then I am going to hotwire the violet/white wire from a point in the harness where it still gets 5v.
Old 08-04-2006, 07:44 PM   #255
Ground is fixed on the TPS now.
