Old 08-04-2006, 07:58 PM   #256
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
Ya know.. When I swapped the new harness into my Horizon, there were two harnesses near the battery that used the same plugs, I got them reversed and had a helluva time figuring that one out.. You didn't do something similar, did you?
Una is offline
Old 08-04-2006, 08:09 PM   #257
Nope, i didnt mix anything up.
Im using a AA body engine harness, and the P body engine bay harnss. That meant for some reason the signal ground wire was missing from the engine harness connector. The signal ground was located on the 19 pin connector for the starter. You cant mix them up becuse the wires are totally different. Everything else on the engine harness connector (grey and black) are the same.
I have to go figure out how Im gonna fix the 5v signal now.
Old 08-04-2006, 08:33 PM   #258
Ah, are you mixing AA and AP harnesses?? If so I think that may be your problem... Look at the color of the wires on either side of the connectors, they should be the same color...
Edward Kelly
Kelly-Mulhern Performance
www.kmperformance.com
c2xejk is offline
Old 08-04-2006, 08:58 PM   #259
Una
Engine: 2.5L Turbo
What a nightmare.. Good luck.
Una is offline
Old 08-04-2006, 09:43 PM   #260
Ondonti sure mastered using a multimeter quickly. Impressive as always.
NA2ndgen is offline
Old 08-04-2006, 10:05 PM   #261
I wouldnt call anything quick. Ive spent like 20 hours with the thing.
Oh, and I drained the battery on my spirit from having jumper cables hooked up all day to trouble shoot the duster.
Old 08-04-2006, 10:32 PM   #262
I still remain impressed.
The battery thing..... . I know how you feel.
NA2ndgen is offline
Old 08-04-2006, 10:40 PM   #263
Una
Engine: 2.5L Turbo
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
We use one just like that at work to keep the car turned on all day long. Very handy. Pretty decent price..
Una is offline
Old 08-04-2006, 10:52 PM   #264
need a car that can start to buy stuff
Edit, yay, my roomate came home.
BTW, I was messing with the wiring, and it seems I just cliped the wrong feed wire.
Anyways, I know whats wrong with the signal wire now.
Old 08-05-2006, 12:12 AM   #265
Yay, the TPS is fixed. I now get 5v at the power line, and the signal line starts around .58v @ idle and goes up to 3.62v at WOT. Problem was that I had AA body engine harness and AP body engine bay harness. For some reason the TPS wires are all different between the two and everything else is the same. I had to do a little cheating on the wiring but it works!!!!
I will advanced the timing so it sounds healthier.
Old 08-05-2006, 01:04 AM   #266
TERRIFIC!
I really admire your perseverance.
Way to go!
Now I can go to bed and sleep. Man this thread is addictive!
NA2ndgen is offline
Old 08-05-2006, 01:04 AM   #267
Una
Engine: 2.5L Turbo
Rock on! I'm glad I was right.. err, I mean I'm glad you got it fixed.
Una is offline
Old 08-05-2006, 01:06 AM   #268
:d
NA2ndgen is offline
Old 08-05-2006, 02:25 AM   #269
Well the car went about 8 blocks :P Now I got to push it home tomorrow.
The wideband all of a sudden decided it didnt want to work when I went out for my drive (just read 21.00) and the single wire coolant temp sensor was not working. grrrr.
It seems after the engine warmed up, it wants to go into closed loop, but since my o2 isnt working right it doesnt get any feedback and dies if Im not careful.
Also, it died when I accidentally pushed in the clutch at about 3000-4000 rpms and the motor dropped to zero.....then wouldnt start again when I let the clutch out again.......made some weird slipping noises on the clutch I think. Grrrrrrr
Looks like I got more problems.
On the good/bad side, The car is insanely loud........and i definitly have a large power loss in the low rpms with this cam. Im sure I dont have the classic 3.0 flat torque line.
Old 08-05-2006, 04:26 AM   #270
My Ride: 94 Plymouth Duster
Engine: 6g72 181c.i.d.
Damn, that sucks w/ the cam thing. I went mild and still noticed I lost considerable low end. But Top end kinda makes up for it.
DustyR/T is offline
Remortgages | Mortgage Calculator | Xbox Mod Chip | Free Credit Report | Deals On Products
Powered by vBul
