09-20-2006, 08:12 PM
#346
well it ran for about 25 seconds and there is no oil below the cam.
Not sure where a blockage could be in the head. just had it all apart and cleaned everything up......head got a bath again.
Hoping its not the block
09-20-2006, 08:25 PM
#347
Pulled the rocker arm bolt that goes through the oil feed
it has oil on it but the others dont.
09-20-2006, 08:39 PM
#348
Wonder if the cam bearings were installed wrong blocking the oil port?
09-20-2006, 11:00 PM
#349
There are no cam bearings
Oil has to go through the rocker arm tubes first.
09-20-2006, 11:21 PM
#350
My Ride: 1993 dodge daytona
Induct: S/C
possibly you have a pressure leak and are losing enough oil pressure for it not to make it up into the head? maybe the oil pump is faulty and sucking air?
09-21-2006, 01:00 AM
#351
Sorry, thinking out loud, and thinking V8/V6 OHV,
09-21-2006, 06:45 AM
#352
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
Is it possible that you installed the rocker tube assemblies on the wrong head? Make sure that the oil feel holes are in their propler location.
09-21-2006, 10:12 AM
#353
My Ride: 94 Plymouth Duster
Engine: 6g72 181c.i.d.
Dang Brent, you must be banging your head against the wall. I know I would be after all you've been through with this motor. You've got patience. Why the heck would oil NOT be getting to the head?
Just thinking out loud, but if he wanted to test to see if oil were getting there, could he (w/ heads off and ignition disabled) turn the motor over and see if oil shoots out of the block? I never said it wouldn't be messy, but it would be easy once you have the heads off.
09-21-2006, 12:56 PM
#354
My Ride: 89 Shelby Daytona
Engine: 2.2L T2
dang dood. You are having enough problems with this build. I had a oil pressure issue in my 2.5L Daytona Shelby and it turned out to be the fuel pressure was to high and too much fuel was getting into the cyl. Some of it pushed past the rings and thinned the oil out. Took me 2 rebuilds to figure out the Aftermarket adjustable FPR was a POS.
09-21-2006, 04:10 PM
#355
Well my oil pressure is great. the sunpro gauge is quite inaccurate IMO (its leftover from previous owners project) but Im getting 75 psi at idle (I think this value is not accurate, but i at least can tell if something is wrong. Stupid P body's dont have an oil pressure gauge).
My thought was i will remove the timing belt, then remove the rocker assemblies, and check to see if oil is getting to the head when I crank the engine over. I will then proceed from there. I dont have time to mess with it till friday evening.
Oil pump is a brand new high performance toga.
Last time I had the heads apart the rear head was getting a crapload of oil. the front head seemed to be having problems before and now it seems worse.
09-21-2006, 05:25 PM
#356
Induct: S/C
75psi seems way too high at idle. a good rule of thumb is 10psi for every 1000rpm's. 75psi is good for like 5000-8000 rpm's if you ask me. if you have 75 at idle then your going to have like 130-150 at high revs.
second, if you are not getting any oil in the front head, you can remove the valve cover and start the engine to see why. i have done this before and it wont hurt anything as long as you dont run it to long of course.
09-21-2006, 10:13 PM
#358
valve cover has been off, thats how I know its not oiling. I need to see what part of the passage is possibly blocked. Im going to start with removing as little as possible and work from there.
09-22-2006, 07:31 AM
#359
cool beans. If you had the block apart, you could pour oil down individual passages and see which ones come out the bottom. I know thats out of the question at this point in time, and I hope it doesn't come to that period. I would absolutely be FURIOUS if I had to do that.
09-22-2006, 01:48 PM
#360
My Ride: Daytona R/t
Engine: Turbo III
Originally Posted by c2xejk
I bet you have a chunk of RTV lodged somewhere... 75 psi idle is way too much...
I dont think so, not if the motor is still cold. My R/T reads about 60-65 when I first start it when cold. And thats on an autometer gauges. When it warms uo it drops to about 15 at idle.
~Tyler~Salt Lake City~Proud SDAC Memeber~
-92 Daytona R/T (PVP Pilot Car)
-92 Daytona R/T
-87 GLHS #907
-86 Omni GLH-T
-70 Plymouth Cuda 440-6pk (in progress...sort of)
Check out my Homepage
"Half the people you know are below average"
