Old 12-14-2006, 09:35 PM   #616
If the bearings were lubed well when you assembled there is no way they would have been damaged turning it over with the starter. If I had allready smoked the rod bearings before,my eyes would be glued to the gauge.
You stated before that you were not sure how accurate your guage was.
XR Tuner is offline
Old 12-14-2006, 09:54 PM   #617
they were lubed. i lubed the journals and the bearings.
I probably turned it over for about 8 minutes total on 2 different days when I was not getting oil pressure.
Old 12-14-2006, 10:02 PM   #618
regarding the rod, I didnt look at the top bearing on #4. Im guessig if the rod was bent then the top bearing would be worn on the opposite side.
Old 12-15-2006, 01:25 AM   #619
Turbo224's Avatar
My Ride: Daytona R/t
Engine: Turbo III
Images: 256
Sounds right to me.
Turbo224 is offline
Old 12-15-2006, 06:05 PM   #620
Good call on the bent rod.
I just looked, the top rod bearing is worn on the opposite side. Crappy......now I get to pull the head.
So Im guessing there is no problem with the rod journal, and this explains why I couldnt plastigauge it using a different bearing.
Old 12-15-2006, 06:52 PM   #621
My Ride: 1993 dodge daytona
Induct: S/C
how did the rod bend?
btw...if i ever meet you in person will you play me in poker?
m90daytona is offline
Old 12-15-2006, 08:38 PM   #622
Lightbulb
My Ride: '89 2.5 Turbo Spirit
Engine: 2.5 Turbo
We're one step closer to seeing some awesome burnout / drag racing / street racing videos from this turbo V-6!
You ought to be pretty good at pulling heads and other engine parts by now!
Throughout this topic, it has never made sense to me how the engine was having oil pressure problems. Now we know. Use the proper size bearings and make sure the rods aren't bent!
Tim_K is offline
Old 12-15-2006, 09:01 PM   #623
Authorized TD Vendor
My Ride: Spirit R/T
Engine: 3L V6
It might make sense that he was having oil pressure problems (on initial crank) if he didn't pack the oil pump with engine assembly grease or vasoline.
c2xejk is offline
Old 12-17-2006, 12:35 AM   #624
Well its been snowing like crazy so I dont see myself taking off the head and pulling the rod to get it checked out.
Leaving for Seattle on the 22nd so maybe january :P
Old 12-17-2006, 12:51 AM   #625
Turbo224's Avatar
Engine: Turbo III
Images: 256
Not sure if the rods had any machine work to them, but any chance they were machined wrong? That would sure be easier. That sucks though man. You seem to be taking this pretty well though.
Turbo224 is offline
Old 12-17-2006, 01:52 AM   #626
#4 rod was resized. Im assuming the rod got bent when the bearing spun. I really dont know :P
Old 12-17-2006, 12:39 PM   #627
My Ride: '88 Shelby Z TII
Make sure that the rod side clearance is in spec when you put all this back together! If it's not, and the rod is allowed to flop around excessively while running it *could* tweak it....
Reaper1 is offline
Old 12-17-2006, 06:46 PM   #628
Old 12-17-2006, 07:00 PM   #629
My Ride: 89 Daytona
Engine: 2.2 T2
Feedback: (8)
Images: 17
snow! I'm glad it isnt snowing here yet..
jory is offline
Old 12-17-2006, 07:02 PM   #630
Our snow is all gone,
Page generated in 0.19615 seconds with 8 queries
