Old 07-11-2007, 07:10 PM   #1021
lol I got 2 4 6 working good but I forgot to put the boots back on 1 3 5 and fouled them out again lol :P
Old 07-11-2007, 09:09 PM   #1022
My Ride: 1993 dodge daytona
Induct: S/C
haha...i know the feeling!
m90daytona is offline
Old 07-20-2007, 02:27 AM   #1023
crap I have a new injector short that happened overnight. drove the car yesterday. Today #4 and #6 are flooding the same way 1 and 3 were flooding before. So far finding the possible short has not proved as easy.
Im taking the car apart to remove the transmission so Im not really sure how much I will get done on tracking down this stupid bugger.
I dont really know any good ways to test where the short is (or to prove there is a short).
Old 07-20-2007, 04:34 PM   #1024
drained the trans oil and TONS of metal came out
Old 07-20-2007, 05:56 PM   #1025
Tranny time!
Ntrain2k is offline
Old 07-20-2007, 06:31 PM   #1026
i just pulled it out, called the trans guy, he had already gone home
Gee that was fun pulling motor/trans in 2 hours in 100+ heat with no shade
I had to take like 4 breaks :P
Now Im going to work to tell them im quiting
I need to study for LSAT so I can try to stay in this school for law school.
Old 07-20-2007, 08:40 PM   #1027
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
Gotta love this heat wave we're having, eh?
That's why I haven't touched anything but this damn A/C belt on my van.
By the way.... Good luck with that test.
mwinkle353 is offline
Old 07-20-2007, 09:13 PM   #1028
Wont be taking it till sept 19th I think.
I want to spend some time on the cars and relax too.
Old 07-22-2007, 04:00 PM   #1029
Induct: S/C
if you have and ohm meter, you can check for a short to ground by putting one lead on the wire and one lead on a known good ground and see if you have continuity. if you do, then trace the wire to the short.
Old 07-22-2007, 06:13 PM   #1030
um
I dont really understand.
The fuel injector wires dont have power fed to them unless someone is cranking so its not so easy..........
Old 07-22-2007, 09:32 PM   #1031
Engine: 3.0L V6
you can try jumping the ASD relay for your troubleshooting needs.
Old 07-23-2007, 06:42 AM   #1032
My Ride: Neon SRT-4
Engine: 2.4 Turbo
Images: 30
Originally Posted by Ondonti
um
In a continuity test, the meter itself provides current to the circuit which must be isolated.
XxPichulonxX is offline
Old 07-23-2007, 05:48 PM   #1033
erm.....I dont really know how to do that then.
Old 07-23-2007, 06:20 PM   #1034
Resident piston cracker
crazymadbastard's Avatar
My Ride: 92gtc vert
Engine: 2.5 8v
Feedback: (21)
easy- just turn the vom to the continuity test setting- you can just touch the 2 testing leads/probes together and then you hear a beep if the ohms are less than 300omhs. So if you test something it will beep if you have continuity.
edit- there are also "noid" lights you plug the light where the injector goes and it lights up when it gets power.
never had a need for them but hey seem handy to have.
dyno sheet
fmic install:
crazymadbastard is online now
Old 07-23-2007, 10:23 PM   #1035
well unfortunately that test didnt find anything useful.
Read like 30 ohms between each injector feed wire (and 15.6 between each injector and the ground).
Gas Suppliers | Internet Advertising | Car Loan | Online Advertising | Personal Loans
Page generated in 0.54369 seconds with 13 queries
