Old 07-16-2006, 06:40 AM   #91
You can pull the lifters/rockers without redoing the timing belt... The trick is to apply tension to the timing sprocket when you unbolt the rocker assembly...
This assumes that you can get access to the cam sprocket. The front head is easy. The rear head is more difficult...
Edward Kelly
Kelly-Mulhern Performance
www.kmperformance.com
c2xejk is offline
Old 07-17-2006, 10:47 AM   #92
I dont have a/c so its pretty easy.
One thing I just remembered when talking to mike this morning......
I only need to shim 66% of the cam diameter change. OOOOOOPS.
ARGGGGG
Old 07-17-2006, 01:08 PM   #93
BTW I dont understand what is ment by applying tension to the timing sprocket..........
Old 07-17-2006, 04:20 PM   #94
Okay, i did some measuring with feeler gauges.
stock cam is ~ .109" tall at the bottom of base circle. My cam is ~.054" from bottom of base circle.
.055" removed
.055*.66 (adjusting for rocker ratio)=.0363" thick needed for washers. Im gonna go shopping for washers now.
P.S. I removed the rocker arm assembly without doign the timing belt. the front cam popped up a little bit but I can just push it back down. The rear cam didnt pop up at all because the timing belt has less leverage on the shorter cam (I think).
Old 07-17-2006, 08:30 PM   #95
The ratio is the other way around... The valve end moves more than the cam end of the rocker...
Edward Kelly
c2xejk is offline
Old 07-18-2006, 12:51 AM   #96
I think you need to check my math again. We have a stock cam lift of .212".
Valve lift (after 1.5 ratio) of .350" lift.
I lost .055" material on the cam and since I am re-adding thickness on the valve side of the rocker, I only need to add 66% of the cam height loss. 0.363"
Even if I add the correct thickness washer, the fact that they are flat means I would get too much lift.
I was previously adding .067" thickness to the rocker side, which equals .100" on the cam side. oops.
Old 07-18-2006, 06:34 AM   #97
Ok, here you have the ratio in the correct direction.
Think about this again. If the valve side of the rocker moves more, then you have to add more to that side...
No disagreement that you need a curved washer...
Think about that again...
Edward Kelly
c2xejk is offline
Old 07-18-2006, 02:35 PM   #98
.067" does not close the valves
All that matters is that the valves close.
I have no idea why they dont close at .067" shimming since that should be lower then the needed shimming.
I am going to check the diameters of the cam NOT AT THE Lobes to see if the mitsu cam was caste thicker then the chryco cam.
DOH.........I just remembered my valves are longer then stock....oops. I told my machinist I was already going to need to shim the lifters.
I may not need to shim at all..........ARGE. My machinist may have tried to idiot proof my motor and then here came super brent to foul it up.
Old 07-18-2006, 07:40 PM   #99
Heh!
Super Brent...
Ntrain2k is offline
Old 07-18-2006, 11:04 PM   #100
Look there! Out on the Street!
It's a Duster!
It's a Spirit!
It's Super Brent!
*plays theme song*
mightymulhern is offline
Old 07-18-2006, 11:51 PM   #101
crappy.
Well using the smallest shim I have which gives .046" lift increase (the actual washer is not this thick) I still got intake backfire. I am going to remove the washers and run just the stock lifters.
Old 07-19-2006, 06:11 PM   #102
Well I put it together, no shims, still backfires in the intake.
I am a little bit confused. going to check the can timing and make sure the distributor is right.
I get the feeling the distributor is off one tooth (im not sure how this is possible since it previously started). The car hardly wants to turn over.....if I advance the timing all the way to the left it turns over faster..........
Old 07-19-2006, 06:58 PM   #103
Well I just spent 5 minutes pulling a few things apart. It looks like my distributor is off for some reason........I cant understand why since the car ran once and I havent touch the distributor.
I lined the front cam up and the dist aint pointing to the #1 contact
Old 07-19-2006, 07:19 PM   #104
If the motor runs when I feel like trying again, then I probably can shim the lifters back up. I feel pretty stupid. Im not sure how it ran for 10 seconds....
Old 07-19-2006, 09:24 PM   #105
Well I got it to start for like 2 seconds........I think it might need those shims :P It sound really high pitched.
