07-23-2006, 10:50 AM
#119
My Ride: '88 Shelby Z TII
I hate wiring problems..the thing is that these cars are getting to the point where it is common occurance. I agree to get it back to stock and go from there, but I think your true issue lies in the wiring. It sounds almost like the injector harness is grounding iteslf out causing the injectors to open up 100% intead of pulse from computer commands. We know it's a fuel problem because #1 it has spark(it does run), and #2 it isn't compression because it does start and run(remember you only need three things for an engine to run fuel, spark, and compression). It could be that something having to do with the commands for the engine to run are messed up too. You need a diagnostic tool that will show what the computer is seeing though to deterine that.....
