11-03-2007, 07:08 PM
#1186
Removed my fuel pump today and confirmed its REAL not a chinese one
Note how its shiny and smooth on the outside. The fakes are dull colored and not so smooth. The fakes look like a brighter aluminum color with sandpaper feeling surface.
The other pump is the one I damaged in that big electrical problem I had.
The pump on the left is from Foward Motion 3 months ago, the pump on the right is from TU about 1.5 years ago.
11-03-2007, 07:55 PM
#1187
My Ride: 1985 Daytona Z
Engine: 2.2 inline 4 Turbo 1
11-03-2007, 09:36 PM
#1188
Thats just a walbro repackaged for another company to sell at higher price.
11-04-2007, 06:51 PM
#1189
11-10-2007, 04:47 PM
#1190
11-10-2007, 05:17 PM
#1191
My Ride: 1993 Dodge Shadow ES
Engine: 3.0 V6
Damn, Ondonti, how many times have you had the motor in & out of that car now? 5 at least? Looks like you're getting pretty good at it, anyhow.
When you changed the clutch, how much wear was left on that 3 puck disc? Did you put it back in?
11-10-2007, 05:43 PM
#1192
that clutch only has 150ish miles on it.
11-10-2007, 06:57 PM
#1193
My Ride: 92 sundance duster
Engine: 3.0L 24v
how many times have you pulled that engine so far? lol good job, and btw that that double spring or something PP you mentioned earlier?
11-10-2007, 07:52 PM
#1194
Its a single diaphragm. similar to the sachs plate I broke in that picture. +40% clamping force over a tIII. Combine that with an insanely aggressive 3 puck solid disc and we have fun.
11-11-2007, 01:51 AM
#1195
Engine: 3.0L 24v
ahh. was that the sach's HD pressure plate? i have that and a 4 puck in my 24v, im hoping its enough  Cindy said it was good to 350ish hp, dont recall what torque though
11-11-2007, 02:01 AM
#1196
The Sachs that I broke is +40% over TIII also.
11-17-2007, 01:18 AM
#1197
My Ride: LeBaron conv. 3.0L
Engine: 3.0 Chrysler/Mitsu
Ondonti, I've been following this car for some time now (various sites). Please tell me about your turbo. I'm working on a DOHC swap (megasuirt and all that crap) for the better heads (and steel crank), BUT I want to run a SINGLE turbo (in the Y-pipe, as yours is).
What's the hot side size? I have a single .48 (.42 compressor) and wonder if it's worth hybrid-izing, or whether I should just look for another unit instead of trying to "hotrod" the POS I already have. PM if you don't want to clutter this thread with my 'jacking... I'd really appreciate the info - no matter how it gets to me ;-)
Again, I've followed your 3.0 for some time, much props for your accomplishment(s)!!!
Best Regards,
LeBeercan
11-22-2007, 07:01 PM
#1198
My Ride: 1995 Avenger
Engine: 420A DOHC
Hey Ondonti, what size fuel injectors are you using? Im thinking of buying this 94 Duster 3L 5spd with a bad motor for $200. I know i gotta get the forged internals, do some head work and some of the other stuff you did. I dont feel like going back and looking for what you used.
11-22-2007, 10:37 PM
#1199
right now just using 30# ford high impedance injectors.
11-22-2007, 11:52 PM
#1200
I just put new plugs in and started the car up.
Vacuum and a/f look good and the engine sounds good except I need to losten the 3 bolt flange on the bottom of the downpipe and crank the V band on the turbo down (need to tighten the vband first or it wont seal up properly because of how the exhaust hangs.
Weeeeee
Dang happy.
