Old 11-25-2007, 09:59 PM   #1216
Super Moderator
bansheenut420's Avatar
My Ride: 92 White IROC RT
Engine: 2.2 L T-3
Images: 117
That ride last night was the scariest/most fun ride I have ever had in a car! The video really doesnt do it justice. Good job Brent.
Cory Hedin
bansheenut420 is offline
Old 11-25-2007, 10:29 PM   #1217
My Ride: 1993 Iroc Daytona
Engine: 3.0 V6
Images: 2
Got it to work.....OH ....MY....GOD brent that things got BALLZ
irocelectric93 is offline
Old 11-30-2007, 01:16 AM   #1218
Tank lid comes out into the engine bay. I put this where a normal car has the charcoal canister. Pump sits behind the bumper.
Mmmm stealth
Old 11-30-2007, 05:14 AM   #1219
Super Moderator
Engine: 2.2 L T-3
Images: 117
Damn nice install. Let me know what your plans are tomorrow night, and I will bring you that m5 jet you need. Plus Jesse and nate want to see the car.
Cory Hedin
Old 11-30-2007, 05:36 AM   #1220
Turbo224's Avatar
My Ride: Daytona R/t
Engine: Turbo III
Images: 218
Mmmm stealth
Awesome!
~Tyler~Salt Lake City~Proud SDAC Memeber~
-92 Daytona R/T (PVP Pilot Car)
-92 Daytona R/T
-87 GLHS #907
-86 Omni GLH-T
-70 Plymouth Cuda 440-6pk (in progress...sort of)
Check out my Homepage
"Half the people you know are below average"
Turbo224 is offline
Old 12-02-2007, 08:56 AM   #1221
My Ride: 94 Plymouth Duster
Engine: 6g72 181c.i.d.
6g72 sohc with t67 turbo, cams @6psi and no traction - Video
Here is the complete video
Tons of crazy stuff at the end.
Definitely need to make a video like that in the daytime so it can be seen easier.
DustyR/T is offline
Old 12-02-2007, 02:33 PM   #1222
lol car is covered in snow now
Need to finish some school stuff and hopefully the snow goes away. Cory is going to come down here and we will try using his wideband controller since mine is dead to tune the car and see if we can safely increase the boost. I think im gonna run E85 in the alky system for now. Im basically just using it to add fuel as I dont need the octane right now.
Old 12-03-2007, 10:02 AM   #1223
Since my custom intake manifold allows me to easily unplug the connectors from my fuel injectors....I can make the engine run on just 2 cylinders.
4 & 6 must be fouling out bad or something. I can run the engine on just cylinders 1 and 2.....and also on just cylinders 3 and 5.
When i have the engine running on
4, 6 and any combination of 1 2 3 5 it runs horrible
Run the engine on JUST 1 2 3 5 and the engine behaves just the same as if all 6 injectores were plugged in.
So 4 and 6 are fouling out or getting too much fuel or something.
I know the injectors are not stuck open because I had this problem before and they were not leaking then and when i swapped injectors into this intake manifold I did not keep them in the same order.
I also tried a different ECU.
On a lame note....my 3.5L dodge AIS motor seems to be stuck open.? anyways its not my main concern.
Just out of curiosity what Spark Plugs are you using? Platinum tipped spark plugs fail when they come in contact with oil in the combustion chamber with almost certainty. And oil in the combustion chamber can become common on a 3.0 or a turbocharged motor. I would think regular copper NGKs would be the best...
Scotty is offline
Old 12-03-2007, 01:48 PM   #1224
copper champions and autolite resistors
Ive probably had 30-40 plugs in the engine over the last 6 months.
Right now it has 4 champions and 2 autolites because crap got on two champions (think it was from that crappy gasket I roughly cut out for the TB) and fouled them. I was in a hurry that night to go play around with Bansheenut's car so i wasnt real interested in cleaning off the copper plugs and making them work again.....or swapping all the plugs.
Old 12-03-2007, 02:00 PM   #1225
My Ride: 92 sundance duster
Engine: 3.0L 24v
in my experience, on a japanese motor, NGKs seem to run better. i ran them in my 12v with good results and im running them in the 24v now as well. *shrug*
Shadow24V is offline
Old 12-03-2007, 02:43 PM   #1226
Normally run NGKs but the only place that carries them is Napa and quick plug replacements dont facilitate shopping at a place the closes way to early and is not very close.
Old 12-16-2007, 05:56 PM   #1227
I figured out today why it fouls plugs.
The engine runs really really rich at sub 1000 rpm idle and the camshafts mean not a lot of compression (also the pistons cause that).
So if I start up the engine and let the rpms get below 1300 or so rpms (like if it dips to 800-900) then it will misfire (cold engine) and foul the plug.
So theoretically to start the car I have to adjust the idle speed higher until it warms up. Then once it warms up, turn it back down. When I have megasquirt in then I will have a lot more control and I think this problem will go away because I can idle it lean.
Old 12-16-2007, 05:58 PM   #1228
The bad thing is that while I have been messing with the plugs after I fouled them, the plugs stopped sparking to the tip and they are now sparking from the body of the plug to the intake maanifold (Testing plugs by inserting them into the boot, then laying them on the intake manifold and turning the engine over with the injectors unplugged.
You look to see if the spark is strong at the electrode and not sparking anywhere else.
Anyways its not working (always has before) even with a new plug......
Edit: I tried on my spirit and it does a similar thing. I guess the cold air is making things act funny
Old 01-31-2008, 02:48 PM   #1229
Yay for this email I got
Originally Posted by Zeitronix
Your Zt-2 opened the internal fuse to protect your car wiring from the harness short.
We can replace the fuse with a new style self resetable fuse and test your Zt-2 at the same time.
We also offer upgrades to the latest specs, which include metric and English units.
To upgrade the Zt-2 to the latest rev 12 specs which includes the ZAVT-1 control, linear wideband output and adjustable NB switching point you will need to send your Zt-2 (and the LCD if you need to upgrade it- does not support metric/English units) to Zeitronix. We perform all necessary software and hardware upgrades and ship your unit back within 1-3 days.
The upgrade cost is $49 plus shipping. Continental US UPS ground shipping is $12. Please include payment with your Zt-2 unit. Please use paypal account sales@zeitronix.com or provide detail credit card info.
sucky thing is that I left the LCD in utah so I have to wait till I get back.
Old 01-31-2008, 07:11 PM   #1230
Engine: 3.0 V6
Images: 2
Well there you have it
