05-15-2008, 01:15 PM
#1383
Passenger innertie rod is bent, so thats why it dives to the right when I launch at the track.
Alignment guy thinks the car is too light in the rear. That means the rear gets loose when I try to correct any torque steer (like from the bent tie rod). I was a bit scared to let him drive the car but him driving it changed his mind about the problem.
My quick fix right now is taking the rear tire pressure from 34psi to 26psi. The tires still dont sit down on all their tread though. I might try even lower tire pressure, maybe 20 psi. He suggested putting a few hundred pounds of weight in the rear of the car since according to him "the rear of the car weighs like 100 pounds" but long term thats not something I can easily do. This might mean that in the future I would want to run slightly wider tires in the rear, especially for street driving. I am sure drag skinnies work great at the track, but those tires are made to grab the track surface well.
