Old 05-22-2008, 01:23 AM   #1396
Yay. I move the shifter cables to a different spot on the body but they are too long now. Oh well, it shifts better. Only problem is I need to make sure one of the cables doesn't try to get in the way of the gas pedal.
Old 05-22-2008, 07:47 AM   #1397
My Ride: 1990 Daytona ES
Engine: 3.0L V6
Nice work, Did you put some white lithium grease on the shifter rod for ease of motion?
Cable interfering with the gas pedal does sound scary!
roguetrip is offline
Old 05-22-2008, 03:12 PM   #1398
I did not lubricate anything. Maybe i will put some engine assembly lube in there.
Old 05-23-2008, 09:22 PM   #1399
Lube always helps...
Ntrain2k is offline
Old 05-23-2008, 09:25 PM   #1400
any picks of how you moved the shifter, i have derlin bushings now and still find it bit hard to shift, probley mostly because of my custom shifter, like 1.5 inches of throw
mopar3.0 is offline
Old 05-23-2008, 09:30 PM   #1401
You can see the shifter is sitting on electrical boxes. I just bolt it down wherever I want it. I made the shifter cable holes higher in the firewall but I just realized that the cables are way to long to do that. The car has J/G body cables in it right now which are also "extra long" compared to P body cables.
Your shifter probably sucks just because you cut the shifter.
Send a stock shifter to Jackson and he will lengthen the throw below the ball instead of cutting the shifter a bunch.
Old 05-23-2008, 09:49 PM   #1402
that what i did i copyed his design, just have to get use to it and the clutch too i guess
mopar3.0 is offline
Old 05-23-2008, 10:01 PM   #1403
My Ride: 95 Caravan SE
ooooooooo ...... naughty
lookin is offline
Old 05-23-2008, 10:09 PM   #1404
Lube'd up.
Shifts better even though the cable is still too long.
I clocked the shifter sideways a little bit so its easier to make the 2-3 and 4-5 shifts.
Old 05-31-2008, 04:59 AM   #1405
Well this car is leaving the hole great!
I was able to get a 1.75 and 1.76 60' tonight.
My secret was actually getting a slight burnout in 2nd gear (but the clutch still slips at the end of the burnout )
Then when the amber lights start going, I ride the rev limiter. Datalogs show I am leaving with 5 pounds of boost on my T67!!!!!
Clutch slips etc in 1st gear though.
Best pass was 13.0@104 (clutch yucky) and we turned the boost up to 9.5ish and the car ran slower and the clutch was more pissed off.
I am hoping I can keep up the 1.75 60's and maybe do better with the clutch fixed.
I will post up the timeslips. My 60' takes no effort. Its just ride the rev limiter, dump the clutch while keeping it WOT
I have to jut wait until the car feels like it isn't accelerating anymore though because I cant tell when its time to shift by RPMs since the clutch is slipping or slicks are spinning and hitting the rev limiter. Launching SO balls out was really really fun. Launching with boost is awesome. Its 5psi when I drop the clutch and it instantly goes to 6 8 or whatever I have the boost set to.
The datalogs I remembered to take on my 2-4th passes were very helpful. I was trying to get the 12.99 but upping the boost didn't help anything. I could probably run the same times with 6psi boost
Old 05-31-2008, 05:06 AM   #1406
Super Moderator
bansheenut420's Avatar
My Ride: 92 White IROC RT
Engine: 2.2 L T-3
Images: 119
It was AWESOME the way the car was leaving the line tonight! Props on a good setup! With a clutch, your car is going to be lethal.
Vids to follow tomorrow, when I can keep my eyes open.
Cory Hedin
bansheenut420 is offline
Old 05-31-2008, 07:42 AM   #1407
My Ride: '93 Dodge Shadow ES
Engine: 3.0 v6
Congrats on your runs. Finding the right launch technique is always a challenge.
Be careful you don't damage the flywheel with the clutch slippage.
What clutch set-up are you going to use?
SpeedyEd
SpeedyEd is offline
Old 05-31-2008, 01:41 PM   #1408
Way to go Brent!
A 13.0@104 1/4 pass ..... with a .... bad clutch!
lookin is offline
Old 05-31-2008, 01:46 PM   #1409
My Ride: 92 sundance duster
Engine: 3.0L 24v
get any videos of your passes?
Shadow24V is offline
Old 05-31-2008, 04:14 PM   #1410
bansheenut got them on video and so did a few other people.
I actually used one of the peoples videos to prove that on my first pass I was shifting too early which was helpful. He showed me while i was in the pits (woodrowz on this website).
