210-230 cfm @ .400-.500" lift?
IMHO: Turbo is [way] too big. Cams are [WAY, WAY] too big. Revving past 6,000-ish, why bother? That's all likely beyond SOHC 24v and into
DOHC territory, much less 12v range. If using a multi-meter was so tough - really over-stepped yourself playing GURU!
I saw the video and heard the motor struggle... And read the posts where you jumped it and swapped harnesses and jumped it and swapped (as clueless as a toddler with a .357 magnum)...
MS would help but "7500 RPM and 10
psi" are a waste of time. Best case scenario.
It's actually offensive that "some people" DARE to offer advice, know what I mean?
I've followed your posts for a long time, funny how "how do you use a multimeter?" to "expert running a 13.0 sec 1/4 with 11 seconds worth of parts" becomes a
TD Deity!!!
Not trying to be $h!tty, just fail to see how your progression from "WTF do I do" to "I'm wasting parts like a fiend" to "I'm a God" really hopped off. Sort of sickening, when one stops to think about it. At least the posts where the harness impedance was AFU were "kind of" amusing. Actually, all things considered, the whole situation was hilarious.
LMAO! Be Cool!!!
3-o
