Old 06-23-2006, 12:56 PM   #1
stumbling stalling.... in an auto???
My Ride: 00 Cirrus
Engine: 2.4
Well, got my 3 liter runnign decent..now when I drive it, it stumbles when it is slowing down,kinda bucking, liek the gas is stillpressed down while I am slowing down, then it stumbles and abotu dies,or DOES stall once at a stop...
now,I know that speed sensors were an issue in my old VNT Comp car.. this sound like the same deal?? in my v6 auto??
thanks in advance..
oneslow30 is offline
Old 06-24-2006, 04:04 PM   #2
My Ride: 93 Duster
Engine: 3.0 V6 6G72
Induct: S/C
1/4: 14.620
I'd check the MAP sensor. My Spirit had those symptoms way back when, and that was the cause.
Avenger is offline
Old 06-24-2006, 09:37 PM   #3
My Ride: 00 Cirrus
Engine: 2.4
Hmmm, interesting thought, and that WULD be load dependant (as in in nuetral or in drive) then wouldnt it? hmmm, could I use one off a 2.2 turbocar?? buddy has abotu 15 stock oneslaying around to go with allthe ld harness'
Old 06-26-2006, 08:52 AM   #4
My Ride: 1994 Caravan turbo!
Images: 4
Which transmission? 3 speed or 4 speed? You need to tell us in order for us to help you.
big_P is offline
Old 06-26-2006, 07:49 PM   #5
My Ride: 00 Cirrus
Engine: 2.4
Well, guessing 4 speed, as its OD, 3, the L
Old 06-27-2006, 06:55 PM   #6
i had a 2.2L do the stumble and buckitis with a bad O2 sensor and a leaky fuel filter lol
Jetson8294 is offline
Old 06-27-2006, 06:57 PM   #7
My Ride: 00 Cirrus
Engine: 2.4
but whats weird,its only stumblign at idle. and it dowenshifts hard when its almost at a stop, otherwise, runs like a raped ape
Old 06-27-2006, 10:42 PM   #8
My Ride: 93 LeBaron sedan
downshifts hard, get ur tcm updated, if its like a hiccup at idle then u may as well get used to it.
Boogieman142 is offline
Old 06-27-2006, 11:11 PM   #9
My Ride: 00 Cirrus
Engine: 2.4
Gotta buy a new module or Mopar need ot flash something? expensive?
Old 06-27-2006, 11:30 PM   #10
it can be reflashed depending on the year. To get it re-flashed it will cost about 60-75. a new one will be like 200-300
Old 07-08-2006, 08:08 AM   #11
My Ride: 94 Plymouth Duster
Engine: 6g72 181c.i.d.
when I called the dealer on my 94 3.0 604 and 543 they said that they can't re-flash those at all. Was he full of it?
DustyR/T is offline
Old 07-13-2006, 12:53 PM   #12
My Ride: 93 Duster
Engine: 3.0 V6 6G72
Induct: S/C
1/4: 14.620
Yeah, but they may not have the connectors anymore. I got my 94 Spirit re-flashed twice, with the 97 update and the 2000 upgrade. The 543 doesn't have anything to flash!
Avenger is offline
Old 07-14-2006, 07:11 AM   #13
You can't use a turbododge Map.
Check your speed sensor.
Ntrain2k is offline
Credit Card | Internet Advertising | Loans | Proliant Harddrives from IT247 | Hypnosis
Page generated in 0.47153 seconds with 13 queries
