Old 06-27-2006, 02:53 PM   #1
6G72 tranny
are 6G72 trannies univeral. Well not universal but are they like the 2.2's trannies where different cars trannies can be swapped. My mom has a grand caravan with the 6G72 engine which apparently is rare because nobody around here can find the tranny. The mechanic says that you can't but he's kindof a dipshit so I need a second opinion.
Wormser is offline
Old 06-27-2006, 03:56 PM   #2
My Ride: 93 LeBaron sedan
i'm assuming it is auto cause
1. it is a grand caravan and
2. you are asking about a transmission for the 3.0
The autos are junk not so much the 3 spd. but the 4 spd is. They are not rare, it is just hardto find a working transmission. most of them get sent to the yard b/c of the tranny, the engine is great. You will need to find another tranny from a 3.0 b/c of the water inlet pipe. good luck and if u want try www.car-part.com, there are a lot of yards on there
Boogieman142 is offline
Old 06-27-2006, 05:39 PM   #3
if your mom doesnt mind driving a stick.. have it converted to a 5spd... that would eliminate your transmission problem... i beat the snot out of my 3.0/5spd combo and the transmission is still smooth as butter.
Jetson8294 is offline
Old 06-27-2006, 09:28 PM   #4
+1 on that, and for something even better, put 568 internals in it.:-)
Old 06-27-2006, 09:32 PM   #5
My Ride: 93 Sundance Duster
Engine: 3.0L V-6
or just find a good A670 3 spd. I doubt anyones mother would need 568 internals in a A543.
93sundance is offline
Old 06-27-2006, 10:24 PM   #6
yea, but ya never know, i see some older ppl driving like maniacs
Old 06-28-2006, 06:35 AM   #7
My Ride: 1994 Caravan turbo!
Images: 4
I did the 3.0 5 speed conversion in my 95 voyager, my DD. Very nice. Quick as hell, too.
big_P is offline
Old 06-28-2006, 01:48 PM   #8
i plan on putting the 568 internals in my tranny... anyone know if the 3.85 FD will go into the 543/523?
Old 07-09-2006, 12:53 PM   #9
My Ride: 92 sundance duster
Engine: 3.0L 24v
the 6G72 bolt pattern is 100% mitsu, so the other 6G72 trannies will bolt up, ive seen a tibby 6sp on a 6G72 as well. in that case, just about ANY 6G72 or 6G72 derived tranny will bolt up, whether its from an eclipse, diamante, galant, sonata, tibby, 3KGT, etc
Shadow24V is offline
Old 07-09-2006, 01:45 PM   #10
yes the 3.85 fd will fit in it
Old 07-09-2006, 02:26 PM   #11
Hey wormser...
Im about a hour from you... and have a a604 tranny I pulled from a 3.0 spirit that had a bad motor. I only drove the car onto the trailer, but it didnt seem to slip at all and the PO told me it drove fine before it started smoking.
Anyways, the localy JY's are wanting around 800 for one, ill go $350 OBO if you are intrested. PM me and Ill get you my phone #.
TurboShadowES is offline
Old 07-09-2006, 05:28 PM   #12
My Ride: 94 Plymouth Duster
Engine: 6g72 181c.i.d.
6 speed tibby? I know it's a tiburon, but will our CV's work on it?
DustyR/T is offline
Old 07-09-2006, 11:34 PM   #13
Engine: 3.0L 24v
im not sure, the person who did it was going to use it in his neon auto-x racer. maybe a hybrid shaft? or changing the hub assemblies?
heres the gear ratios if anyones interested
1: 3.153
2: 1.944
3: 1.333
4: 1.055
5: 0.857
6: 0.704
Old 07-10-2006, 12:17 PM   #14
My Ride: '88 Shelby Z TII
I keep seeing a LOT of this missinformation on here. The A604 is NOT a junk tranny. STOP preaching this! It is a matter of opinion and personal experience. Built and cared for propperly they will last a good service life, AND they can hold a good amount of power. They get better milage than an A670 also.
A568 gears are NOT needed in A543's unless you are looking for different gear ratios. Open one up one time and take a look...you'll see what I mean. There are VERY few people that could even take advantage of the A568 strenght advantage(wich comes from heat treating and a VERY slight pitch change on the teeth). The higher FD is not an advantage to the V6 due to its already prodigious torque down low. I'd even suggest finding a 3.5 FD to put in one over the 3.77. If you're worried about the diff, #1 STOP doing peg leg burn outs, #2 use diff pin savers, or #3 use some sort of traction control device, you CAN put Quaifes in these trannies!
Reaper1 is offline
Old 07-10-2006, 01:06 PM   #15
My Ride: 87 Shelby Lancer 120
Engine: 2.2L I4
AMEN Brother
Tom
Egodriver71 is offline
Remortgages | Loans | Mobile Phone | Online Advertising | Download movies
Page generated in 0.40966 seconds with 13 queries
