Old 07-11-2006, 02:12 PM   #1
Limit of stock fuel system
My Ride: 94 Duster
Engine: 3.0 V-6
I have read that the 3.0 fuel system doesn't have much capability left in reserve. So I am wondering, if I use an adjustable pressure regulator, how much more fuel pressure is safe for the stock injectors and pump? (I guess the stock fuel pressure is about 45 psi)
I am considering a 50-ish dry shot of nitrous (I don't have a turbo) and I need the absolute cheapest way to increase the fuel
dustbuster is offline
Old 07-11-2006, 02:48 PM   #2
My Ride: 89 Shelby Daytona
Engine: 2.2L T2
Probably a B&M Command Flow AFPR kit. I think summitracing.com carries them for ~$60
Harvii is offline
Old 07-11-2006, 03:19 PM   #3
How much capability depends on how you setup the system... For normally aspirated setups, nothing needs to be done to support a bunch of extra hp. The stock computer is very adaptive...
For a turbo, auxillary injectors and RRG's need to be used when in boost. So far the stock pump has been able to keep up on Stein. I have turned down the base pressure, used oversized injectors, RRG, and auxillary injectors... So far DaytonaStein has put out enough power to pull off a 98+MPH run with two people in the car...
The fuel pressure deadheaded at 78-80psi... plenty of fuel and still more available...
For nitrous I would recommend a wet setup (ie nitrous and fuel.) No need for AFPR or RRG.
Edward Kelly
Kelly-Mulhern Performance
www.kmperformance.com
c2xejk is offline
Old 07-11-2006, 03:27 PM   #4
My Ride: 94 Duster
Engine: 3.0 V-6
The only B&M Command Flows I can find are for Hondas and the 95-99 Eclipse 2.0 turbo (but they're only $40 on jazzproparts.com).
Will the mitsu one fit on my Duster 3.0? I thought all the engine management stuff was Chrysler parts.
Ebay has some universal regulators with built in gauges for about $40, I was thinking about getting one of those, but I'm not sure how precise the adjustability will be on them.
Old 07-11-2006, 03:43 PM   #5
My Ride: 94 Duster
Engine: 3.0 V-6
The one thing I'm worried about with wet-nitrous (at the throttle body) is pooling of fuel in the manifold. Do you think this is a concern? The bottom is nice and flat, looks like a good place for fuel to collect.
Old 07-11-2006, 09:21 PM   #6
My Ride: 93 LeBaron sedan
port the plenum if ur worried about it. I wouldn't be worried about it.
Boogieman142 is offline
Old 07-12-2006, 12:00 AM   #7
the dry setup will run like crap.
Old 07-14-2006, 10:40 AM   #8
My Ride: 94 Duster
Engine: 3.0 V-6
Ok, wet it is, I kinda figured that.
I saw some Zex kits on ebay for around $200, that sounds like a good deal. Zex sounds like a good system, and it will probably work much better when I do the turbo too.
Old 07-14-2006, 04:40 PM   #9
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
Keep in mind that the stock pump is only good to about 240-260hp. Now matter what size injectors or extra fueling components you install, that pump just won't flow above that power level without leaning out.
mwinkle353 is offline
Old 07-14-2006, 04:44 PM   #10
I don't believe that fuel puddling is a significant issue. A bigger issue would be variations in fuel charge going to each cylinder... So far on Stein, cyl 5&6 appear to run a little richer than rest. (based on pulling the sparkplugs.)
Edward Kelly
c2xejk is offline
Old 07-14-2006, 04:49 PM   #11
The exact limit of the fuel pump _is_ effected by fuel pressure. The higher the pressure, the lower the hp limit.
That said, I would bet you can squeeze a little more out of the pump if you are creative...
Edward Kelly
c2xejk is offline
Old 07-14-2006, 05:50 PM   #12
Engine: 3.0L V6
voltage augmentation.
Old 07-14-2006, 07:34 PM   #13
That is strange. On my turbo 3.0 spirit, I had 5& 6 going lean under boost......I figured this was because air was being forced to the rear cylinders with my backwards plenum.
You running 5&6 lean worries me though. That doesnt make sense.
Old 07-14-2006, 09:11 PM   #14
I have two cold start injectors that I think provide a little more fuel to 5&6 than to 1-4... Plugs 1-4 looked "right", 5&6 looked slightly rich...
Edward Kelly
c2xejk is offline
Old 07-14-2006, 09:43 PM   #15
Just running big wires to the fuel pump would probably be good enough to get atleast another 5-10 hp worth of fuel out of it... From their you could always add one of those devices to boost fuel pump voltage.
With my current setup, turning down the voltage (when the manifold is at vacuum) would help me get a little more hp out of the stock pump. Then I could turn down the base fuel pressure a little more and run larger injectors...
Edward Kelly
c2xejk is offline
Refinance | Remortgages | Credit Card | Hypnosis | Mobile Phones
Page generated in 0.44395 seconds with 13 queries
