09-01-2006, 04:37 PM
#29
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
Originally Posted by c2xejk
The question is, what are going to do to make the Chrysler 3L V6 really perform at 7K RPM. Stock, the hp curve is dropping off well before 7K. Putting nearly stock heads on a block that has been stroked will likely pull the peak hp rpm point down...
If you doubt, compare the 2.2L and 2.5L... Hp is only up SLIGHTLY.
Just look at the dynographs of those who have them for the 3.0L motors. The torque starts dropping off at 4500. And it's not an easy drop-off. It damn near plummets. That's why our motors make max power near 5k, and don't seem to acclerate past there.
Get a custom set of cams, wich will allow better flow in the upper rpms, and alot of head work; then you may be able to use rpms over 6000 to your advantage. Until the day that these parts are added to your motor, you're stuck with the 5500rpm or less power curves of our motors. That's why it just doesn't make sense to ever need to hit the rev limiter of our motors.
