Old 09-09-2006, 01:15 PM   #1
Injectors....
My Ride: '88 Plymouth Voyager
Engine: 3.0 V6
Hi Folks,
I dug out the previous discussion on injectors in this section and didn't really get what I wanted out of it. I'm working with an '88 3.0 in a Voyager, I think I've also got an '89 fuel rail in a box somewhere, and an '89 lower intake.
What I'm aiming for is better atomisation and maybe a touch more fuel than stock, i.e. a few percent, not like 30%
So, here's the "facts" I think I'm working with. Stock system is regulated at 48psi, low impedance 19-20lb injectors. That's right huh?
Here's what I want to know. Is the injection system voltage controlled in these? Meaning can one possibly take out the ballast resistors and run high impedance injectors?
What fittings are the injectors, thread etc? Some other sites seem to suggest ford/bosch injectors fit, but people here don't seem so sure.
What I'm thinking I'd like to get to work, are the Ford 19lb injectors that are stock on a lot of mustangs, because they're the 4 pintle type giving a good spray pattern, are reputed to be reliable and may flow a touch more than our stock injectors (Due to being rated at lower PSI). Also they're often available real cheap.
So can anyone tell me if I'm likely to get those to fit in either the '88 setup or the '89 parts I've got.
If those are a definite no-go, then what cheapish equivalents might I find that give a good spray, and aren't much bigger than stock. I'm thinking the 27lb ones will be too big for me.
This is for a rebuild/buildup that I hope will happen before Xmas, just getting my ducks lined up and allowing myself lots of time to collect parts as cheap as possible.
thanks,
Road Warrior
RoadWarrior222 is offline
Old 09-09-2006, 01:36 PM   #2
Originally Posted by RoadWarrior222
Hi Folks,
... and an '89 lower intake.
Go with a 92 or later lower intake. They are slightly larger than the older ones.
There are no threads. They are push in o-ring fittings.
I believe they are the same as ours, and so yes they will fit. I don't know if the spray pattern is any different, but I doubt it.
NA2ndgen is offline
Old 09-09-2006, 01:51 PM   #3
My Ride: 93 Duster
Engine: 3.0 V6 6G72
Induct: S/C
1/4: 14.620
I'm pretty sure the Ford 19lbs'ers are exactly the same as ours. I've got to go to Autozone this afternoon anyway, I'll check P/Ns for their replacement parts.
Avenger is offline
Old 09-09-2006, 05:19 PM   #4
My Ride: 93 LeBaron sedan
they are the same, the other thread i started was for a mitsu lower, not the chrysler ones ford and chrysler like to use the same external size of the injectors and resistance.
Boogieman142 is offline
Old 09-09-2006, 05:25 PM   #5
Sorry for the hijacking... but does anyone know if the stealth TT motor has low or high impeidence.. its a 91 stealth
Jetson8294 is offline
Old 09-09-2006, 05:45 PM   #6
Engine: 3.0 V6
See this for Stealth injection details...
http://www.stealth316.com/2-injectortypes.htm
Old 09-09-2006, 06:19 PM   #7
My Ride: 93 Duster
Engine: 3.0 V6 6G72
Induct: S/C
1/4: 14.620
Advance lists no fewer than 3 different P/Ns for the Ford, one of which is the same number as for the 93 P-body.
Avenger is offline
Old 09-09-2006, 07:28 PM   #8
Engine: 3.0 V6
Thanks Avenger, yeah by '93 they were on high impedance I think, and '87 might have had different injectors (Lower fuel pressure apparently) So probably means ford/bosch "Stage III" injectors are a direct swap in for later high impedance 3.0s.
Thanks for clarifying that Boogieman, easy to get confused between mitsu installed spec, chrysler installed spec, hyundai installed spec, etc.
I'm looking at this page...
http://www.geocities.com/phatfoto/EEK6G72.html
Which says only 2 types of lower manifolds were installed. Well, I'm sure the '88 one is an '88 one, but the '89 could be any year I guess, got a mixed lot of parts from a guy who had an 89 and some were parts off his 89 and some were spares he got for it, so could be any year, anyhoo, the spare one I've got has the PCV connector on it, and is different from the 88 one. The spare fuel rail I've got looks a bit different too, but I dunno if it's the SMPFI on, but I hear I should be using the 88 one anyway for best flow (Not that I'm trying to max it)
That page is confusing though, I heard somewhere else roller cams were 91 not 90.
So, so far, ford injectors fit, later lower manifold flows better, earlier fuel rail flows better...
So I'm thinking I just need to find out about the injector driver and whether there's any resistances I can remove to be able to run high impedance on the '88. Might be messing around with something to speed up closing time, might not. I'll eventually have something like a "second guess" injector control system, that will sometimes override the ECU and suppress or enhance injector pulse duration. Haynes manual is bloody useless as always, got a wiring diagram that is undated and appears to show a later SMPFI circuit, since the injectors appear to be driven independantly. No mention of differences in it either.
Old 09-12-2006, 10:16 AM   #9
Oh crap. I should have known it wasn't that easy after getting the sandwich adapter. I hope you guys wont mind me asking this. Is it likely the OE injectors on my 1995 3.0L are worn enough to merit replacement? Would I get better performance with new injectors of a certain type on my NA setup?
NA2ndgen is offline
Old 09-12-2006, 04:51 PM   #10
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
are you running lean? If not, then don't worry about replacing them. I'd just run a few tankfulls of injector cleaner a few times a year to keep them from gumming up.
mwinkle353 is offline
Old 09-12-2006, 08:56 PM   #11
Thanks Wink.
NA2ndgen is offline
Old 09-12-2006, 09:07 PM   #12
Engine: 3.0L V6
No worries. Just doesn't make sense to "throw" money at a car that doesn't need it. Unless it's to say you have "sucha-sucha" part installed. And to me, that's just being a ricer.
Old 09-12-2006, 09:32 PM   #13
I agree. If there is no real improvement, or power gain, then it is just silly. Or ricey if you will.
NA2ndgen is offline
Old 09-13-2006, 04:36 PM   #14
Engine: 3.0L V6
Honestly, the best fuel modification for a N/A application is an adjustable fuel regulator. If you do get lean, after some heavy modifications, you just crank up the fuel pressure a bit to even things out. But the PCM's Fuel Adapt range is fairly wide on our cars. And it'll take alot in order to surpass it's capability. Best thing to do is get your hands on a diagnostic scanner that reads the PCM's fuel adapt percentages. Then you can take your car for a drive and adjust your Adapt percentage adjustment as close to 0% as you can.
Old 09-13-2006, 04:40 PM   #15
What soft of mods? I am guessing ported heads and a 60mm TB would do it.
NA2ndgen is offline
Currency Converter | Teen Chat | Personal Finance | Advertising | Best Credit Cards
Page generated in 0.44324 seconds with 13 queries
