Old 09-22-2006, 09:20 PM   #1
sick hood scoops!!!!!!
My Ride: 1993 dodge daytona
Induct: S/C
what do you get when you combine a turbo coupe w/ a daytona?
m90daytona is offline
Old 09-22-2006, 09:24 PM   #2
Induct: S/C
turbo coupe guys would kill me for cutting up a perfectly good (and rare) turbo hood.
i still need to tack weld it in and putty the seem but thats for another night.
Old 09-22-2006, 10:48 PM   #3
My Ride: 2 messed up dodges
Engine: 10:1 3.0 5 speed
Images: 1
sweet!
jory is offline
Old 09-22-2006, 11:29 PM   #4
My Ride: 89 Plymouth Horizon
rice.
nemesismachine is offline
Old 09-22-2006, 11:37 PM   #5
Tape is sexy.
Old 09-23-2006, 12:32 AM   #6
My Ride: 93 Duster
Engine: 3.0 V6 6G72
Induct: S/C
1/4: 14.620
"rare" turbo hood? I see the things all the time, every other T-bird competing at National Trails has that hood.
Avenger is offline
Old 09-23-2006, 07:12 AM   #7
Induct: S/C
Originally Posted by nemesismachine
rice.
why is it rice? the s/c setup i am using produces alot of heat. in fact it produces so much heat that if i push it i can cuase case distortion and ruin my charger. the hood scoops are functional and will help cool the s/c and make it more reliable. plus, it will flow past the plenum, reducing engine compartment heat and intake charge temperature that will result in greater hp gains. the scoops dont stick up or stick out. they help w/ reliability and hp so if thats rice then i guess a dodge viper and Z06 is rice too? if you dont like something that doesnt mean its rice. functional hood scoops have been around long before rice burners.
Old 09-23-2006, 10:05 AM   #8
My Ride: 1990 Daytona ES
Engine: 3.0L V6
nemesismachine loves raising the rice flag, lol
I like it, wish i had cutting skills like that, but is the hood gonna close ok with the upper plenum installed?
roguetrip is offline
Old 09-23-2006, 01:00 PM   #9
Induct: S/C
yeah, actually looks like i still have an inch or 2 left. the nice thing about the daytona hood is that it has 2 "natural bulges" that come down each side which made clearance problems no problem at all.
Old 09-24-2006, 09:05 AM   #10
My Ride: 92 Iroc R/T Red
Engine: TIII
I like it.
Tim
charger R/T is offline
Old 09-24-2006, 10:08 AM   #11
My Ride: 85 GLHT, 87 ShelbyZ
The problem is you're pressurizing the engine bay now. That keeps air from moving through the rad and will hurt your cooling system and downforce generated. Looks good though, but they need to go somewhere like the air intake.
GLHNSLHT2 is offline
Old 09-24-2006, 12:44 PM   #12
Induct: S/C
i cut the rear weatherstrip out so the air flows through the engine bay. theirs no use pushing air in if you cant get it out.
Old 09-24-2006, 01:16 PM   #13
Im only playing around, i just like the clean look.
Old 09-25-2006, 09:19 PM   #14
Nope. How can you pressurize the under hood area when you have 2 little holes in the hood letting air in and one BIG hole in the underside? If anything, that hood should help cooling just a wee bit. Besides, there is a dead boundary layer of air just above the hood line on any car. (watch some wind tunnel testing, and you'll see what I mean) Air will not be FORCED into those inlets, more so, it will be sucked in by the pressure differential ABOVE the openings. For a hood scoop to have air FORCED into it, the scoop opening must be above this boundary layer, and placed into the actual airflow over the hood.
Those vents should actually allow a little cooler air to flow over the engine, and should not impact radiator/cooling negatively at all.
440trk is offline
Old 09-25-2006, 10:04 PM   #15
My Ride: TIII R/T
Engine: 2.2L TURBO III
Feedback: (9)
personally if i ever do my gen 3 hood, im building the stock bulges up and then cutting them out like a Trans Am or a Grand Am Gt
xtrempickup is offline
