Old 09-26-2006, 10:19 PM   #1
stupid boost question
Hope you guys don't mind me asking this. I have always wondered what a pound of boost is. It it one pound of air pressure over atmospheric pressure at seal level or what?
My other question is this. What would 1 pound of boost get ya?
Thanks in advance.
NA2ndgen is offline
Old 09-26-2006, 11:13 PM   #2
My Ride: 1993 dodge daytona
Induct: S/C
psi=pounds per square inch so 1 psi is 1 pound force applied to 1 square inch. how much h/p you get out of 1 psi has alot of variables like altitude,intake temp,compression,ignition timing,fuel delivery,bore,stroke etc...but a good rule of thumb is 10-15 hp per 1 psi.
m90daytona is offline
Old 09-26-2006, 11:27 PM   #3
A good rule of thumb is NA hp/14.7 psi. Atmospheric pressure is 14.7 psi and at that pressure the engine makes it's NA hp.
For the 3L V6, NA hp (stock) is 141hp (crank.) So 1 psi will buy you 141hp/14.7psi or 9.6hp/psi.
However, that is a rule of thumb since NA engines can not bring the plenum to atmospheric pressure without something like a "ram air" setup...
For another reference point, Atmospheric pressure is about 28-30" Hg. So 1psi is roughly 2" Hg.
Edward Kelly
Kelly-Mulhern Performance
www.kmperformance.com
c2xejk is offline
Old 09-27-2006, 11:39 AM   #4
Thanks you guys. Now I have a better idea about it.
Appreciate it.
NA2ndgen is offline
Old 09-27-2006, 12:58 PM   #5
This is one of the reasons I recommended a vacuum guage... With it, you could tell if you are loosing hp because the plenum pressure is dropping as RPMs climb.
According my scantool, my van has this problem. Going to a 60mm Jeep 4L TB helped, but not as much as I had hoped... I may look at stepping up to a bored out (62mm) TB. At ~5K RPM, the vacuum is in the 2-3" range...
That said, I should probably get a differential pressure guage to make sure it is the drop across the TB that is causing the problem...
Edward Kelly
c2xejk is offline
Old 09-27-2006, 04:50 PM   #6
Now I see why. Sadly I really didn't get it before. As soon as I can I will get one. That will help me to recalibrate my butt dyno. I swear my ram air made a noticeable difference, but the vac gauge will be the final authority on it.
Thanks Ed.
NA2ndgen is offline
Car Loan | Books | Car Credit | Xbox Mod Chips | Internet Advertising
Page generated in 0.37698 seconds with 13 queries
