Originally Posted by m90daytona
a 600 hp supra cant run 11's?  it will usually run 10's and trap higher than any big block will. not to get off the subject but the fastest 6spd 1/4 mile car in the world is a supra. dont believe me then look it up.
....First of all, I said
" 600 HP Supra *usually* can't run 11's".
I didn't say it was impossible, only uncommon. The sad reality, is that a 500hp (that's 100hp LESS) Big Block can and usually will run mid-low 11's all day long....and POSSIBLY even dip into the 10's, depending on the setup. I can't say I recall ever seeing a 10 sec. Supra that "only" had 600hp. I've seen MID-11 sec. 600-625hp Supra's.. Sure, a few exist, but MOST of them are dyno queens. Lack of torque is WHY the MPH will be higher to get the SAME ET...not to mention the additional wear and tear on the driveline components revving the thing to the high heavens to MAKE that HP.
Hence my original response (which WAS related to the post), as the question was asked regarding the effect of the intake spacers.
Not trying to argue (or hijack the post...sorry bout that) it's just that removing torque to make more HP is counter productive(unless you are severly traction limited)....but hey, if that's what ya wanna do, more power to ya.
I'm not bashing the Supra's mind you...I was only using them as an example.
We now return you to your previously hijacked thread....
On-topic related:
Lengthening the runners AND smoothing that transition, along with the already ample plenum size on a 3.0, should increase both HP and Torque. By how much? I Don't know....and a Dyno test would be interesting. Hopefully the increase is enough to make them a viable upgrade.
Again... sorry for the hijack.
