10-15-2006, 04:06 PM
My Ride: 2 messed up dodges
Engine: 10:1 3.0 5 speed
I'd be interested if they were available. 3/4" sounds good, I'm pretty sure there is enough room under the hood for that.
10-15-2006, 04:17 PM
My Ride: '92 Lebaron GTC
Engine: 3.0L V-6
5/8" or 3/4" sounds beautiful and should fit, I have 1/2" ones on my GTC with no clearance issues at all, there's still some room so something slightly thicker than mine would be perfect. I wish mine came with bolts, I managed to find ones at home depot that fit though, use METRIC THREADS!
They made a good difference on my car and my plenum stays a lot cooler all the time, I suggest getting them!
-Steve Reject.
10-15-2006, 05:41 PM
Originally Posted by NA2ndgen
My 7/8" ones caused no clearance issues, on my 95 Caravan anyway, and in fact I am pretty sure still I have another 1/2" of clearance.
I'm surprised you don't have more room in a minivan. I haven't spent much time looking under the hoods of the vans, but I figured there were several inches available there.
Long ago, I thought I read that 1" would fit under some cars but not others. ...might have been old style Daytonas vs the 92+ style. Unfortunately I don't recall exactly.
Just my opinion. But I think the main benefit spacers offer, is a slight increase in intake air velocity, from taking that sharp bend out and lengthening the runners.
Sounds plausible. Widening the turn would be a good thing. In addition it should keep the upper plenum cooler leading to colder air being sucked into the heads.
10-15-2006, 06:06 PM
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
I'd be interested in a set. Prefer the thickest available. 1" would be perfect. But I'll go for the 7/8" units, if that's what's available.
What material are you going to use for these units?
I honestly would use a good set of aluminum ones. Delrin would be my second choice. But if you are planning on useing Phenolic material, I'm not even going to bother with placing an order.
10-15-2006, 06:07 PM
My Ride: 1993 dodge daytona
Induct: S/C
just out of curiosity, the plenum spacers add more torque but decrease horsepower right? i know w/ the 4th gen maxima, one of the trick mods is to take the 5th gen intake manifold off and bolt it on the 4th gen motor. its a variable intake manifold which means below 4k the manifold has long intake runners for torque and then an rpm switch closes a valve which shortens the intake runners giving the car 32 hp and lengthening the hp peak from 5k to 6500k. even the forced induction guys make more hp w/ this mod compared to the stock intake manifold.
my question is since our cars already make a ton of torque, but dont really peak so well stock, wouldnt we be better off w/out this mod?
10-15-2006, 06:10 PM
the spacers make it easier to turbocharge the car. flipping the intake in reverse saves a lot of headaches.
A P body cant not use a 1" spacer.
Barely clears on an AA body. I had to remove a little bit of my hood cause the spacers rubbed in the past.
10-15-2006, 06:12 PM
Engine: 3.0L V6
Horse power wins bragging rights. Torque wins races.
And if you think you have too much torque, then you have traction problems!!!!
10-15-2006, 06:34 PM
Induct: S/C
tell that to the guys running top fuel dragsters making 5500hp and running 4 second 1/4 mile times. or the supras/tt vipers running 8's making 1400whp. fact of the matter is you spend more time taching between 5k and 8k (depending on the car) in a drag race and torque numbers start to die off between 3k and 5k. in an ideal situation, you would have a "torquey" car for good 60' foot times but high revving hp for fast 1/4 mile runs and trap speeds.
top fuel dragsters peak around 9k, 1400whp supras peak between 8k-9k and indy cars somewhere around 10,000 rpms. indy cars usually make around 700hp and only 300 ft/lbs torque. my guess is if you reversed those numbers, the car wouldnt be nearly as fast. and i dont even want to start on bikes.
10-15-2006, 06:46 PM
Aluminum wouldn't insulate the upper plenum at all from the heat of the lower. I don't know how big of a differnece that makes, but we ruled out aluminum on first thought because of that.
Currently we're looking at a cast Nylon material. It has similar properties to delrin but a better working temperature range and acts as a better insulator.
10-15-2006, 07:30 PM
#13
torque #"s dont die off at 3-5k when you make your peak hp at 5-8K.
torque doesnt = good 60' either.
the saying 'torque wins races' mostly refers to cars with more torque usuallyhaving wider powerbands. the car with the wider powerband and similar peak power will almost always dominate.
A well build supra has a good usable powerband. A poorly built supra = dyno queen.
ANyways, this thread is all in reference to our 3.0 not these other motors. We cant rev past 6000 rpms.
10-15-2006, 08:05 PM
#14
Induct: S/C
here is the theory
http://mgcgti.clarkeandclarke.co.uk/Page28.html
you are entitled to your opinion but i asked the question in my first post and nobody has answered it.
is the spacer going to add or subtract horse power? if it adds, then maybe i will spring for one. my guess is it doesnt but nobody has been able to confirm either way. i feel satisfied w/ the amount of torque my car produces and would even be willing to sacrifice some if it would peak better but not the other way around.
btw brent, what where your peek torque numbers/rpm on your last turbo set-up?
