Old 11-09-2006, 11:47 PM   #16
My Ride: 1993 Iroc Daytona
Engine: 3.0 V6
Images: 2
Well i for one am interested in Eds numbers. Lets stay on topic and not fuss over absolutely nothing alright?
irocelectric93 is offline
Old 11-10-2006, 07:30 AM   #17
Bottom line, I am still looking for a stock (or nearly) 3L (preferable 5-sp). By nearly stock I mean CAI and ported plenum are acceptable.
If you are you at all close/interested, contact me.
Edward Kelly
Kelly-Mulhern Performance
www.kmperformance.com
c2xejk is offline
Old 11-10-2006, 08:16 AM   #18
My Ride: 94 Plymouth Duster
Engine: 6g72 181c.i.d.
c'mon, someone has to be local. I'd drive a few hours for a free dyno.
DustyR/T is offline
Old 11-10-2006, 12:53 PM   #19
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
I wish I could bring the baron up there, before the turbos get installed.
mwinkle353 is offline
Old 11-10-2006, 05:24 PM   #20
ecs
Just a little off topic, how much would you charge for just a run on the dyno (I don't have a 3.0 but i do have the 3.3 :P)
ecs is offline
Old 11-10-2006, 05:43 PM   #21
i would try asking the general TD public.
Im sure there is a TDer with a stock 3.0 around you.
Old 11-10-2006, 09:50 PM   #22
Originally Posted by Ondonti
If you are dynoing that low I dont think fixing the intake port is going to help.
I am curious why you don't think the ports are "fixable"? It is a curious statement when you know very little about the curve and results... I consider the results very promising especially considering that I am using stock valves w/ smaller than stock ports.
How many people can make a port smaller and get gains. Flow bench and hp gains... I think more is possible, either by modifying the port or by modifying other parameters of the system.
The problem right now is port velocity is coming on a little later (higher RPM) than I wanted... Fixable by several means...
Edward Kelly
c2xejk is offline
Old 11-10-2006, 09:54 PM   #23
Engine: 3.0L V6
well, as soon as you get done with these heads, I for one will want a set. That's for damn sure.
Old 11-10-2006, 09:56 PM   #24
Thanks for the vote of confidence!
Edward Kelly
c2xejk is offline
Old 11-10-2006, 10:19 PM   #25
My Ride: 93 LeBaron sedan
so then u didn't even get to run it on the dyno yourself, that sucks. I may also have to get a set of those heads also.
Boogieman142 is offline
Old 11-10-2006, 10:22 PM   #26
First time on this dyne... So I opted to watch... I suspect he might let me run it next time...
Edward Kelly
c2xejk is offline
Old 11-11-2006, 02:08 AM   #27
Can you explain where I said the ports are not fixable??????
I said you can fix the intake port all you want but that motor is still dynoing very low and Im sure it has nothing to do with the heads. You didnt say what is done to the motor either, exhaust, TB plenum etc.
Old 11-11-2006, 06:32 AM   #28
sounds like a very unimpressive motor.
Here.... Certainly implies that any changes are not going to fix things. Internet diagnosing at it's worst...
Edward Kelly
c2xejk is offline
Old 11-11-2006, 03:55 PM   #29
I did say that. I didnt say ANYTHING about the intake ports being "fixable"
Old 11-12-2006, 01:53 PM   #30
...mike has an obsession with stating the 3.0 runs 14's with 130whp which is physicaly impossible. Mike uses his crappy dyno sheet to verify his claims about that even though its physically impossible.
Be careful discussing other people's "obsessions" Brent. I never said that 3.0s run 14s at 130whp. On the contrary, what I did say was that I have all of the "typical" mods and am not making anywhere near the power you claim. ...and for that matter I have had 2 different blocks in the car and 2 separate sets of heads on the car so we can't blame those. ...I've also had a 3.0 car bone stock in my driveway to compare the other one to as well as a stock 24v 3.0 Eclipse. My "crappy dynojet plot" backs up my seat-of-the-pants dyne used in the car-to-car comparisons.
Perhaps you and a couple others are making more power than that or perhaps your cars are lighter than you think they are. I honestly don't know which it is. Regardless with the typical bolt-ons people add, most 3.0s do not make close to 200hp and it's very frustrating to watch you mislead people and make childish comments about "kicking the dyne operator in the balls" when someone else starts discussing mods and gains. You really need to cut out the all-knowing arrogance, take a step back, and think a bit. Most likely, there are a combination of differences contributing the difference in power you and I are observing. My guess is that you probably have done something subtle that we don't know about that is bumping up your power. Your car is probably also lighter than you think it is. That is my best guess. All I know is that if John Q TurboDodger throws in a j/y 3.0, slaps the normal bolt-ons onto it, and hits the track, he isn't going to be making the output you claim and he's going to be very disappointed. Been there/done that.
I just don't want to see you doing the same down talk of the 12v. It pisses me off, especially when there is nothing to back up the dyno numbers. There is a good 30-40whp difference between the 3.0's running 14's and the ones running high 15/low 16.
I don't think I'm down talking the 3.0. I simply state facts as I see them based on my own observation and experimentation. I love the 3.0 and have tinkered with mine enough to know what is real and what isn't. You are no more an "expert" than I however the tone with which you address others is often that of an all knowing 3.0 god rather than that of a college student learning as you go. It's that attitude that has led to the rifts that have emerged between you and some of the other experts out there. I like you Brent, but as time goes on, I find myself rolling my eyes at your posts more and more. We're on the same team here. We have the same goal.
"Nothing to back up those dyno numbers." As we've discussed, my drag strip driving isn't very good. ...and as a result, if you take my time slips and run them through an HP calculator, you get far worse power than my "crappy dyno sheet". I'll bet $100 that if even you drove my car it wouldn't exceed that sheet. If you lived in Chicago, I'd pay to put your car and mine on the same dyne back to back to end the debate. We'd either see that you're making a lot more power (which would throw us into the search for why) or you'd be sorely disappointed.
I said you can fix the intake port all you want but that motor is still dynoing very low and I'm sure it has nothing to do with the heads.
Actually I'd say it's dynoing right about where I'd expect it to and the headwork Ed did is very evident in the location of the hp peak. Like Ed, I'd like to see a plot for a stock 3.0. Actually I'd like to see plots for a bone stock 3.0 and one with some limited mods... The more plots we have, the more we can compare configurations. Weight and driver are too big of question marks to compare quarter mile times.
mightymulhern is offline
Company Reports | Adverse Credit Remortgage | The eBay Song | Mortgages | Hummer For Sale
