Old 02-24-2007, 09:28 AM   #196
My Ride: 92 sundance duster
Engine: 3.0L 24v
what are y;ou runing for starting pulsewidths? (under warup wizard IIRC) and whats your req. fuel? also are you boosting yet or is it N/A for now? thanks
Shadow24V is offline
Old 02-24-2007, 09:46 PM   #197
My Ride: 1993 dodge daytona
Induct: S/C
well i swapped alternators today but that one isnt charging either. i know both alt. worked before. i think my ecu isnt regulating the voltage. anyone know how i can check this?
m90daytona is offline
Old 02-25-2007, 01:24 AM   #198
ecs
mmm..... http://turbododge.com/forums/showthr...=128795&page=3
Take a look at post #44 and you tell us
ecs is offline
Old 02-25-2007, 07:59 AM   #199
Induct: S/C
i got the alt. working last night. turns out you cant cut the green/orange wire for the coil because its the same wire for the voltage regulator in the ecu.
my req. fuel is 8.4
prime pulse width 2.0
cold pw 7.0
hot pw 2.5
these numbers still need played w/.
Old 02-25-2007, 09:25 AM   #200
Engine: 3.0L 24v
ECS - i knew he had the M90, i was wondering if he was doing initial idle tunint etc in N/A form
M90Daytona - so without the stock coil the voltage regulator wont work? hmmm, i have my alt hooked up but dont know if its charging at all. think this means we need to get an external voltage regulator?
Old 02-25-2007, 12:23 PM   #201
My Ride: 1993 Iroc Daytona
Engine: 3.0 V6
Images: 2
I think he meant just dont cut the wire...
irocelectric93 is offline
Old 02-25-2007, 01:41 PM   #202
Induct: S/C
you can cut the wire AT the coil, but dont cut it at the relay box because it feeds the coil, fuel injectors and alternator. the coil does not have to be hooked up in order for the alt. to work. i have actually retained everything from the factory except for my a.c. all of my gausges including tach are working and my voltage regulator in the ecu is also working now too.
Old 02-25-2007, 03:29 PM   #203
Induct: S/C
well i wanted to drive the car today w/ the charger hooked up but the bov does not blow off at idle. i have the bov vacuum hose hooked up to the intake manifold but it only blows off after i rev it. does anyone know what kind of bov i need? i need it to let out excess air whenever the throttle plate is closed. thanks.
Old 02-25-2007, 04:06 PM   #204
Engine: 3.0L 24v
i thought that the BOV was designed to vent the excess pressure on sudden throttle releases and over all pressure regulation...
and on the note of the alternater, 90% of my factory harness is there, i just unplugged the coil, i didnt cut the wiring. so i should be ok then?
Old 02-25-2007, 04:19 PM   #205
Induct: S/C
mine is only venting after i rev it. then it closes and stays closed while my pipes start to pressurize and then blow apart. its worse when i start it cold because then its idling at like 2k and the throttle plate is clsoed and it builds up massive pressure in the intake tubing.
Old 02-25-2007, 07:46 PM   #206
Engine: 3.0L 24v
your running your TB after the S/C right? and the BOV should have a non valved vac source i think. check the source then?
Old 02-25-2007, 08:22 PM   #207
ecs
My guess is that it doesn't want to vent at a low psi that is in the tubing at idle. To adjust this there should be a adjustment screw or washers to add/remove from the spring, unless HKS is totally different.
ecs is offline
Old 02-25-2007, 08:39 PM   #208
I will try to ask my buddy. Just got back from driving to vegas in his supercharged Maxima.
Old 02-25-2007, 10:48 PM   #209
Induct: S/C
what year maxima? v1 or v2?
Old 02-25-2007, 11:23 PM   #210
i think its a 99 maxima? 4th gen. Fun car. Makes 300+ at the wheels with 10psi non intercooled.
I just talked to him, he says your HKS (ssqv?) is not compatible with your kind of supercharger setup. You need to get one that will work with a supecharger and can vent like you want it too.
glenmoormax says (9:19 PM):
yeah, the BEST BOV for SC's is a vortech race or vortech mondo
glenmoormax says (9:20 PM):
they have adjusters so you can loosen or tighten them based on your setup, i think i figured mine out and thats why it wasn't leaking anymore
Problem Mortgage | Houses for Sale | Shares | Credit Cards | Personal Loans
Page generated in 0.92969 seconds with 13 queries
