Old 02-26-2007, 08:58 AM   #211
My Ride: 1993 dodge daytona
Induct: S/C
thanks...i will check those out!
m90daytona is offline
Old 02-26-2007, 10:55 PM   #212
Induct: S/C
i bought a vortech race bov on ebay today brand new for $130. i also called vortech tech support and they said it will work fine for what i need it to do so i will let you know.
Old 02-27-2007, 12:21 AM   #213
Okay I hope that information helps you out I really didnt know anything but I know my buddy had to deal with that crap.
Old 02-27-2007, 08:53 AM   #214
Induct: S/C
how does your buddies maxima run? i almost did a maxima instead of my daytona but i wound up using my maxima for work. there is a guy in harrisburg PA who did my tranny,(tilley) he has the second fastest maxima on the org. whats cool about the 4th gen maxima (95-99) is its lighter than the 5th or 6th gen. and if you swap valve covers you can put the 3.5L out of the 350z and still use the factory ecu. then turbocharge and make upwards of 500whp.
btw...i think this charger is going to make more boost than originally anticipated. i have 2 huge boost leaks and it was still making 7psi when i reved it. i hope this bov comes before the weekend...
Old 02-27-2007, 10:41 PM   #215
Induct: S/C
well i drove the car today for about a half hour. its idling great at 800rpm. i was trying to figure out how to use autotune but to no avail. hopefully i will get some more time to mess w/ it before the weekend. right now the car is n/a becuase i am waiting for my new bov.
Old 02-27-2007, 11:31 PM   #216
My Ride: 92 sundance duster
Engine: 3.0L 24v
hey, m90Daytona, what pully diameters are you running? crank and S/C, if your making 7PSI at idle, i will need to ramp it down or ill overboost my motor and blow it up lol
congrats on the idling and driving, once i get my car back, ill be PMing you for more info on your setup, as you got further faster than i have lol
Shadow24V is offline
Old 02-28-2007, 08:47 AM   #217
Induct: S/C
i am not making 7psi at idle. its making 7psi when i rev it. and i am not sure on the s/c pulley diameter (i think its the smallest one you can get) but the udp size is 6in i believe.
Old 02-28-2007, 09:27 AM   #218
Engine: 3.0L 24v
oh, ok, that sounds more like it. lol
Old 02-28-2007, 07:39 PM   #219
The UDP pulley will increase the blower speed, increasing boost. I would reccomend you swap the stock crank pulley on, get it tuned with that, then step it up with the UDP and retune. More room for error on lower boost...
Ntrain2k is offline
Old 02-28-2007, 11:20 PM   #220
Induct: S/C
the udp slows the blower down.
Old 03-01-2007, 06:46 AM   #221
DOH, Your right... I had my thoughts backwards.
Ntrain2k is offline
Old 03-01-2007, 10:31 PM   #222
Induct: S/C
2 steps forward, 1 step back.
the fan wasnt working for some reason today and then i found a short to ground on the f-idle circuit. to make a long story short i spent the last 2hrs ohm checking/wire tracing. i somehow managed to plug my passenger side foglite into my evap pigtail coming from the ecu. i feel retarded. i took the evap solenoid out because it was taking up much needed room. and i havent re-installed the foglites yet. the pigtails where laying next to eachother and so not thinking about what they where for, i plugged them in. why did chryser make the pigtails so close to eachother and w/ the same connectors? i know it was stupid on my part but you would think that a foglite would be physically unable to plug into an evap solenoid pigtail. oh well, its fixed now.
Old 03-05-2007, 03:49 AM   #223
So when is a good time for us all to come over, kidnap you, take pictures of all your plans etc?
Old 03-05-2007, 09:03 AM   #224
Induct: S/C
probably later this week. i finally got autotune to work last night. it works great! i still dont have the charger piping hooked up because i wanted to tune it n/a first. my afr is reading 12-12.5 under wot and its running really well i think. i want to do a little more tuning n/a before i put the charge pipe back on but it looks like i may actually have the car running boost this week!
btw...as soon as i get all the kinks worked out, i will post a more accurate wiring diagram and all of my tuning parameters for y'all. if anyone has any questions, post them on this thread and i will do my best to answer them.
also, i am going to try and dyno this thing as soon as its done. i want to do an n/a dyno and boosted dyno so i will let you know what the numbers are.
Old 03-05-2007, 11:39 AM   #225
My Ride: 89 Spirit ES 3.0
Engine: NA 3.0
The only question I have for you is: Is the optical Dist pickup working well and how did you wire it up?
87turbodance is offline
Mortgage | Property for sale in Spain | Loans | Company Reports | Gift Ideas
Page generated in 0.60864 seconds with 13 queries
