03-06-2007, 08:13 PM
#236
My Ride: 89 Spirit ES 3.0
Engine: NA 3.0
Looking from these wiring diagrams...
Dark Blue - yellow pin 51 can be connected to the fuel pump output of MS pin 35
Black - Gray pin 19 can be connected to the coil output of MS pin 24
Violet - White pin 6 can be connected to the 5vref pin on MS pin 26
Orange - Dark Blue pin 22 can be connected to the TPS signal pin on MS pin 22
A GM 3 bar map sensor can be plugged into the original map sensor connector and mounted in the factory location. For this to work: Dark Greed - Red pin 1 needs to be wired into MS to the MAP signal pin
Tan pin 2 can be connected to the coolant sensor pin on MS pin 21
Black - Dark Green pin 41 can be connected to the O2 signal pin on MS pin 23
New wiring will have to be run on the negative side of the fuel injectors as the factory ECU seperates them into 3 groups and MS can only run two groups.
IAC wiring will need to be added
M90Daytona will have to step in and tell us how he wired up the Dist pickup and the Idle stepper motor
